Old 02-28-2022, 10:18 PM
mr_rye89's Avatar
mr_rye89 mr_rye89 is offline
Silvertone 113/110.700
Look what followed me home today! 1949-50 I think, built by Air King maybe. 12LP4A picture bulb. Knobs, HV cage, rear panel are all present, 5U4GB isn't lol
Old 03-01-2022, 09:32 AM
pallophotophone pallophotophone is offline
General Electric CRT ? I'll bet its still good.
Old 03-01-2022, 09:50 AM
AlanInSitges's Avatar
What a sweet set! It was probably worth more as a 5U4
Looking forward to see progress on this one.
mr_rye89's Avatar
Yep the (GE) CRT is good. I found a burned 4.7k resistor on the damper next to a sketchy looking wax paper capacitor. I may swap those and see if it will come up on dim bulbs. The dang schematic I got is the wrong one, but is similar enough that it took a while for me to figure out. Reading those pf value molded paper domino capacitors is a real pain
Old 03-01-2022, 09:47 PM
Kevin Kuehn's Avatar
Workin' Late Again
Very nice find.
I located in Riders 5-1, as Air King models 12T1, 12T2, and 12C1, chassis 700. Your Silvertone version is way out in Riders 10-1, and they show the exact same schematic as the earlier Air King (drawing number 5958). Seems like the Sears chassis no. 110.700 even corresponds to the Air King chassis 700. It appears they used that same chassis with slight modifications with every CRT size under the sun, including rectangular ones. Oh and you probably know it's basically the same Air King chassis in Sams 121 folder 3.
Old 03-01-2022, 10:57 PM
mr_rye89's Avatar
I couldn't find it in Rider's There's a burned resistor on pin 3 of the damper (6W4GT) the (wrong) schematic doesn't show any resistor on pin 3.....
Old 03-02-2022, 02:31 AM
Very nice find.
I might have a physical copy of the Sam's folder for this TV in my Sam's Photofact Stash that I could upload or email to the OP.
Old 03-02-2022, 10:01 AM
Workin' Late Again
Here's a couple pictures from Riders. Unfortunately I have no way to scan these large pages but these pictures turned out quite clear. If you left click on you can zoom in.
https://live.staticflickr.com/65535/...be7ab96d_k.jpg
https://live.staticflickr.com/65535/...2c168bef_k.jpg
Old 03-02-2022, 10:06 AM
Workin' Late Again
I'm sure that would help with the visual orientation when locating components.
Old 03-02-2022, 01:43 PM
mr_rye89's Avatar
Awesome! Thanks! Looks like it’s a 47k resistor that cooked
Old 03-03-2022, 11:23 PM
mr_rye89's Avatar
Brought it up on dim bulbs. sound works, horizontal runs....drew a teensy weensy arc off the HV anode (at the jug), not enough for a raster. I think this set runs in the 10-12KV range, and that should draw a decent arc. The B+ is low I think. I may just go ahead and get new caps
Old 03-03-2022, 11:24 PM
mr_rye89's Avatar
That would be great if it's not too much of an inconvenience
Old 03-04-2022, 03:16 AM
I believe I found the Sam's for your TV in my Sam's Stash.
See Picture Below.
Old 03-07-2022, 10:27 AM
Workin' Late Again
See Picture Below.
I'm not seeing that as a match, other than it's a Silvertone.
Old 03-07-2022, 10:37 AM
Yeah I realized that after I posted it...
