Old 03-02-2022, 04:16 PM
Sencore VG91 TVA92 cable
I just picked up a Sencore TVA92 that's looks barely used. I also have a VG91 and had heard that you need to connect them together.
That is definitely true. The TVA92 is a brick without it. You can't even turn it on!
Does anyone have the specs for the synchronizing cable that connects these two? If it's just wired straight through, I'm sure I could throw one together.
Old 04-30-2026, 02:29 PM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
39G266 TVA92 cable
I don't have the specs, but I do have the cable. I just checked and it is just wired straight through.
I have schematics for the VG91 if that would be of any use to you.
Sorry for the late reply.
Old 05-05-2026, 09:05 PM
Thanks. I did figure it out a while ago. Just a standard cable as you said.
