Old 06-20-2022, 06:47 PM
Airedale's Avatar
Airedale Airedale is offline
Hobbyist
What did I buy?
Found this GYYR vcr at the local goodwill, looks like it's for a security system?
Can I just pick up some BNC to rca plugs and use it as a normal vcr?
Old 06-20-2022, 08:32 PM
dishdude's Avatar
dishdude dishdude is offline
Won't operate as a normal VCR, it's for a CCTV security camera system. It doesn't record every frame so the tape will last for a few days of footage.
Old 06-20-2022, 11:00 PM
Airedale's Avatar
Hobbyist
Does that mean that it can still play a normal vhs tape? It just records in time lapse style?
For 14 bucks I had to pick it up, I'll find a use.
Old 06-21-2022, 05:11 AM
djski djski is offline
That's a good find if it works. Brand new, those cost much more than a consumer grade VHS deck.If that Gyyr has SP or 2hour speed slection, it might play SP tapes only. Give it a try. Time lapses usually have many hours compiled and it's very likely that the heads are worn out.
Old 06-21-2022, 07:02 AM
Airedale's Avatar
Hobbyist
I ordered the BNC to RCA adapters, so I'll give it a try then.
I've checked it out and it can be set from 2hr or 24hr speed.
Old 06-21-2022, 01:21 PM
Airedale's Avatar
Hobbyist
Just bought a good working 1997 Panasonic vcr for 12 bucks. I'm a happy man.
Old 06-21-2022, 08:38 PM
zenith2134's Avatar
The GYYR is a great unit. Up to 960 hour recording on a typical T-120/T-130.
RS 232 interface for remote, with battery backup, and the 15 pin control bus for alarm controller
Old 06-21-2022, 11:51 PM
One good use of the 960 hour recording function I can think of would be to use it to record Gone With the Wind and 2001 a Space Odyssey, then play it back on a normal VCR at 8X speed...It's probably the only way to make those films NOT boring/too stinking long.
