Old 03-11-2023, 08:41 AM
WildcatMatt's Avatar
WildcatMatt WildcatMatt is offline
What's the smallest 9-pin RS-422 (OEM) controller?
Although I'm perfectly capable of using all the front panel controls on my various pro machines (BVU-870, AG-7750, AU-65H, PVW-2800, AJ-D255), every now and then I think I'd like to have a remote controller on my desk for when I'm perusing a tape. All of these have the typical 9-pin RS-422 connector.
I have a Sony RM-450 which works but I'm not doing any editing at this point so I don't need dual controls and it takes up a fair amount of space.
I also have an old 34-Pin Panasonic remote (AG-A600) which would be almost exactly what I want -- except for the 34-pin part.
I'm not interested in any of the new stuff I'm seeing from the big broadcast sites, I'd really rather have something vaguely contemporary to my gear.
I see one can find some Panasonic controllers (AG-A250, AG-A350, AG-570) on the auction sites but most of those seem to have 25-pin connectors.
Can anyone tell me anything about those Panasonic controllers, or suggest alternate model numbers to look for?
Old 03-12-2023, 01:00 AM
Tim's Avatar
Tim Tim is offline
You might want to look at the JLCooper MCS3.
Tim
Old 03-22-2023, 10:07 PM
I wanted to post an update.
I wound up picking up a JLCooper MCS3 from eBay and I learned a few things.
One, JLCooper is terrible about model differentiation as they sold several versions of the MCS3 in two form factors and you have to know what to look for to tell them apart as there are no model number designations or suffixes to make it obvious whether a given unit is meant to control decks or drive editing software.
The original release of the MCS3 (this applies to the MCS2 also) is deceptively large. It's roughly 9x7 but in photos it looks about half that size. The jog/shuttle wheel has a nice weight and feel but everything else about it is oversized and clunky. At more than half the footprint of an RM-450 I wouldn't call it particularly compact and the example I got was RS-232 rather than RS-422 (but I didn't figure that out until after it arrived).
After that I picked a pair of Panasonics, an AG-A300 and an AG-A350.
The AG-A350 is a true compact dual edit controller which I had some experience with in college. I don't need the "edit" part of the controller but the size is right and it has what I think is a really nice jog/shuttle control and it works perfectly with all my gear.
The AG-A300 is a slow-motion playback controller which uses a T-bar instead of a wheel. It's single-deck and it stores multiple cue points which could be useful. The manual claims compatibility with the AU-65H plus some slow-mo capable VHS decks. This is a typo, they mean the AU-66H.
Still, I thought if it talked the Sony P2 protocol it'd still more or less work with my other decks and it did -- for all but one. With my AJ-D455, AU-65H, and PVW-2800 the T-bar acted like a jog/shuttle control which wasn't all bad. My BVU-870 would not play nice with signals from the T-bar though which was ironic since that's the only deck I have that actually has slo-mo capability.
If I had the time and patience, I'd build a converter that would let me use the Sony SVRM-100A (which talks Control-S rather than P2) as it's exactly the size I'm looking for, or else adapt the AG-A600 (except that 34-pin connector is pretty much unobtainium) and maybe if I ever get bored I'll look into that.
In the meantime, the AG-A350 is good enough for the price I paid for it.
Old 02-17-2025, 08:39 PM
Here's a hugely late comment on this necrothread. Back in the early 90s, a friend and I designed and built a few prototypes of a bi-directional RS422<-->Infrared remote. It would learn IR commands, and translate them into Sony protocol 422 signals, to allow control of pro tape machines from standard consumer remotes. It also had the ability to convert 422 editor commands to IR VTR commands. While consumer VTRs make pretty poor edit machines, it would let you control garden-variety consumer decks. It would also allow computer selection of some custom/user commands, such as placing audio channels in record ready, marking insert edit in/out locations, completing a preview, and executing the insert edit. All from a consumer remote.
We showed it at NAB one year, sold a couple, and the following year there was another less-capable device, IR to 422 unidirectional, and locked to a single type of remote. The only nifty thing about it was theirs used a shuttle/jog knob, while ours used a pair of buttons for shuttle, and a different pair for jog. We couldn't do half-speed, for example, unless we programmed it. Good news is theirs didn't sell much either.
All that said, the OP's A350 is a nice controller for Panasonics.
