Old 04-15-2023, 08:21 PM
zchrisz1986 zchrisz1986 is offline
1986 Fisher television
hi all, i finally found a Fisher PC-420 television i've been hunting for and it has some issues as expected.
the tv has what looks like barrel distortion the corners are pulled in on all 4 sides. also has some lines at the top of the screen that look like vertical comb over.
the vertical/PCC control board is separate from the mainboard. it has two electrolytic capacitors and a film capacitor. all were good but i replaced anyways. it uses a C2168 and A958 transistor which all check out. it appears the transistors are getting ~27 volts and the board itself is getting 89-90Volts from the mainboard.
the PCC transistor is okay as well.
i do not have a service manual for this TV and cannot find one. i'm not an expert in CRT's but i have some electronic knowledge.
anything else i should look for?
thanks
Old 04-15-2023, 11:49 PM
Is the yoke firmly seated forward against the funnel of the crt? If it has slipped back barrel distortion and corner shadow can occur.
Old 04-16-2023, 08:25 AM
https://www.stereomanuals.com/man/re...ls_p-88_xx.htm
They list it. I know nothing about them.
If this is the chassis I am thinking of it has a SMPS with 2 ceramic modules.
They went DISCO in the 90's. There are 2 'lytics in the HV in series. One
is the HV filter the other the 200V filter for RGB outputs. They went &
are near the FBT. Try them first.
The supply should put out a solid & clean ? 130 ? VDC. There is
probably a marked TP for it. BTW If the modules go usually the set goes dead.
Old 04-16-2023, 09:33 AM
thanks for the replies. i did find that website with service manuals but they are long gone.
i've attached some pictures. the vertical board has a test plug that's plugged in not sure how that works.
the tv picture looks great outside of the distortion.
i'll see if i can check some voltages.
the yoke is up against the tube.
Chassis # A7R-42000
File Type: jpg 70318113834__F554D91E-B95B-4AFA-8BE0-C874A33AC519.jpg (137.4 KB, 40 views)
Old 04-16-2023, 10:17 AM
There are two test point posts near the flyback. i grounded my meter probe and i'm reading 85 volts dc on both pins.
jbattles's Avatar
jbattles jbattles is offline
jbattles
looks like your b+ is low check filter cap in ps. i would try that first.
Old 04-16-2023, 04:08 PM
The TP for the main B+ is the cathode of a diode, off the SMPS transformer.
( rear edge of HV PCB ). There may be other diodes off it to run lower
level voltages. The main B+ can be 120 - 140 VDC depending on the set.
Also on the right edge of the HV PCB there is a big black cap. I think its
one of the trouble makers. BUT its been a LOT of years ! The
top vert problem may be another 'lytic IN the vert out. Find the main
problem first. There is probable a beefy diode in the PIN thats in the
hoz out area that shorts on many brands. Lift one end to test.
Zeno
Old 04-17-2023, 11:50 AM
thanks Zeno, i checked all the diodes and the remaining capacitors i didn't change and all check out okay. i've checked all the resistors.
kind of at a loss now. the Vertical/pcc board had two caps i replaced them with no change.
looks like i'm getting 158v dc past the transformer.
Old 04-19-2023, 08:33 PM
i replaced all the electrolytic capacitors with no change. still have 4 lines sagging down from the top. it appears the h width adjustment has to be maxed out to even fill the screen. also have a pair of very small lines rolling up the screen. thought for sure it would be a capacitor.
Old 04-20-2023, 07:53 AM
+1 for suspect PSU.
For indirectly checking the PSU, measure the video amp supply. Is derivated from flyback and usually have 175 to 200V. Suspect if less than 175V. All other flyback derived supplies will be low also then.
Is very uncommon but I've seen sometimes the H tune pulse capacitor (the ones with 1600V ratings in parallel with HO transistor) changing value to less, due to defect (near self destrucion), making image to shrink, but normally this makes all flyback derived supplies to rise (including the video output supply), and affects only the H size. Not seems to be the case, but anyway, if you have a capacimeter...
Old 04-20-2023, 10:46 AM
I found the service manual!!
anyhow it is low B+ 85volts manual says 110-112v. looks like the SMPS is regulating that way. looking through the schematics now.
Old 04-20-2023, 01:39 PM
jbattles's Avatar
jbattles
that's good turn it on and get a hair dryer and heat up around those tree caps in power supply and watch the screen and see if the screen gets bigger and that's a bad cap in there. see it 100's of time. heat up caps in the horizontal caps too. of you do that sometimes you can find the culprit easier.
Old 04-20-2023, 06:59 PM
here's the schematic of the power supply. i'm not getting the 111v specified. i checked the circuit to the best of my knowledge and cannot find anything wrong. does anyone see something i should check?
Old 04-20-2023, 08:23 PM
jbattles's Avatar
jbattles
i see you should gut it and put a fish tank in it. we have telling you where to look, but you don't listen. sorry, but were not there, so you have to try to find it. nobody can help without these measurements it hard to point you in the right direction. look its has a bad cap has either power supply or after to horizontal. to get true b+ measure the collector of h-output. i know everybody say's its a cap, but caps gave trouble when they new.
Old 04-21-2023, 07:27 AM
First there are 2 grounds. One is the primary ( hot ) of the SMPS & the
other the chassis ground. gotta use the right one or voltages
will be wrong.
If the 2 lines ARE from the set its 120 cycle hum & most likely a cap
on the primary side.
Zeno
