Old 05-04-2023, 06:00 PM
pac.attack76's Avatar
Stuck in the past
1979 GTE Sylvania GT Matic CX9164W chassis E24-3
Just got this set in a lot of 4. This one was a huge mess. Got it cleaned up but the plug is cut off at the end of the cord which isn't a problem but I'm hesitant on testing till I know more about the flyback on it. There is a small bulge on top with some cracking and one edge is warped a little. Will it hurt to try or should I replace that 1st? I've circled the areas.
Genesis does what Nintendon't
Old 05-05-2023, 03:49 PM
You gotta work on the pix sizing ! Dont feel bad, I wouldnt know how to
do it either !! I would ask my sons but I would forget in a few days.
Anyhows
It looks like an in line jug. Thats good as the earlier GT matic / Super Set
deltas had a VERY short life. If it were me I would just fire it
up with a variac. You need to confirm the CRT is good BEFORE you
put time & $$$ into it. Post some sized pix of the area also first. All
I can see is what looks like a chunk out of the FBT.
Old 05-05-2023, 04:04 PM
Stuck in the past
I know. I never had trouble till now. Not sure what's going on but I'll getting better ones.
Old 05-05-2023, 04:11 PM
Stuck in the past
Ok, I think I got it. Phone has a resizing option but I never had to use it.
Old 05-05-2023, 07:18 PM
The small thing in the first pix looks like a spark gap. 2nd pix
looks like a tripler that is cracked open & NFG. Dont run it.
After the week end I will see if I have a manual & give more info.
Zeno
Old 05-05-2023, 08:00 PM
Stuck in the past
Zeno
Ok, I'll wait 👍
Old 05-11-2023, 11:16 PM
Those were made from about '75 until '80, when they were replaced by the E32 single-board chassis with an IHVT.
On your set, triplers were a high-failure part, as well as the filter capacitor and bad solder connections. I ran into a few bad yokes and a number of weak tubes on these. When they're right, they have a nice picture. I think the tripler on these is an NTE523A.
Old 05-13-2023, 06:07 PM
Stuck in the past
Looks like it. $25. I'll try to order that soon.
Old 05-26-2023, 10:49 PM
Stuck in the past
Also, what is the filter cap on this? May as well replace with the tripler.
Old 06-08-2023, 02:08 PM
Stuck in the past
New tripler arrived today. Will put in today or tomorrow and update.
Old 06-09-2023, 10:52 AM
Stuck in the past
Put new tripler in and tested. Red breaker on back popped out tripped where do I look now?
Old 06-09-2023, 11:20 AM
JohnCT's Avatar
JohnCT JohnCT is offline
Did you check the horiz output transistor for Collector to Emitter short? If the tripler is punctured it would have arced out and likely damaged the output and possibly the LV regulator.
Old 06-09-2023, 11:27 AM
Stuck in the past
No I didn't. Can u point those out to me?
Old 06-09-2023, 12:47 PM
JohnCT's Avatar
The horiz output will be located on the right side of the chassis near the tripler. One of your pictures shows a metal TO-3 (top hat) transistor held to the side of the chassis near the yellow label with two 1/4" screws. If it's on the right side of the chassis, that's the output (if it's on the left, it's the reg). You can check from the metal body to the chassis ground side rail. It should read open (over 100K ohms). If it reads short (a few ohms or less), the transistor is shorted.
The low voltage regulator would be located on the left side looking from the back. That also might be a TO-3 metal transistor mounted like the horiz output is. That transistor won't be shorted to the ground panel but you can test it by removing it from the chassis and checking resistance between the metal body and the two terminals.
Old 06-09-2023, 12:59 PM
Stuck in the past
Ok I'll check and let u know.
