Old 11-09-2023, 05:08 PM
Bk 440 or 466
Any insight on which crt tester is more accurate the bk 440 or the 466 or more sensitive
Old 11-09-2023, 06:05 PM
ARC Tech-109 ARC Tech-109 is online now
Retired Batwings Tech
I have both a 466 and 467 and they're about the same in terms of accuracy, I can't speak for the earlier 440 model. The 467 is basically a multiplexed 466 that uses some rudimentary logic but regardless of the extra tech they're both milliamp meters measuring cathode current. Personally I like the 466 better as it doesn't have all the extra smarts but the CRT interface plug is a pain if you want to make a breakout cable. I reconfigured mine to work with the 467 Molex connector.
Old 11-10-2023, 02:23 PM
The 466 isn't particularly hard to make a breakout cable for. Without any adapter plugged in the main cable is the standard post war monochrome socket (the 10BP4 and virtually every other monochrome CRT pre 1958 used it) rob a base off a dud tube, brightener, or a scope tube (the scope tubes have every pin populated) and build an adapter. I did that for mine but only made the adapter for one gun...I made the heater leads extra long though. I figure on color tubes it's easier to move the K, G1 and G2 leads than hook up 3 sets of them and on the 466 you can't read them all at once anyway.
Old 11-10-2023, 06:16 PM
I have all the correct plugs for both the 466 and 440 but was wondering which one may be the more accurate and or sensitive.
Old 11-10-2023, 06:42 PM
If you test the same tube with both testers, aren’t the readings similar?
Old 11-11-2023, 12:03 AM
Both are nothing more than a milliamp meter measuring cathode current, guess if absolute accuracy is a concern one could measure this using ohms law and a resistor, I believe but don't quote me the CRT cathode current is about 1.4 ma for full emissions for the triad gun, maybe someone can verify and correct me on this.
I've owned my 466 since the late 80s and trust the accuracy all the way. The only change I made was to replace the G1 pot with a 10-turn and add corrections to the G1 readings on the meter using my Fluke 77 and converting the cable end to a Molex connector so I could use the 467 sockets and make my own for testing computer monitor CRTs way back then.
The numbers are subjective and a marginal CRT can test good with 6.3V on the heaters, drop the heater voltage and note the readings and how quickly they fall off, I've also found a "marginal" reading CRT to look good and retain the emissions with reduced heater voltage and hold the color tracking.
One thing about the 466 is the rejuvenate functions are much softer than the older brute force designs as they use a light bulb as a ballast, they're also a little more refined than the earlier ones but again accuracy subjective.
Old 11-14-2023, 01:48 PM
kf4rca kf4rca is offline
The best one I have ever used was the Heathkit IT5230. Plenty of them on Ebay!
