Old 03-03-2024, 06:16 AM
Linear slide resistor
Is there a way to replace a slide resistor starting at 100k and ends around 1 meg. Keeping the housing but just replacing the resistor strip. I don’t know if aquadag would give the ohms swing that I need, a little over an inch long and 1/8 wide kind of small.
Old 03-03-2024, 07:25 AM
These things are available, Type "Slide Variable Resistor" into google.com to begin
your search. I had to replace a sub miniature slide resistor on a answering
machine more than 10 years ago - they are available. Even if it is not
the exact one, you can find something that will come close enough
that you will have a reliable fix that might even allow it to
be reassembled and look correct. It might take looking
at a number of companies to figure out what brand
made the original.... or comes real close, even
if the pins don't fit the original holes. You
might even try Google, or Bing Image
Search, take a few "good" pictures
and upload it. Also try image
search for results and see
if you get a better match
there....
Old 03-03-2024, 08:59 AM
What's the function of this part in-circuit?
Old 03-03-2024, 09:13 AM
It is for a tuner in a Sinclair mtv1 but can’t find what the exact ohms are
Old 03-03-2024, 06:25 PM
Get a roughly 900k pot, and a 100K fixed resistor and put them in series....when the pot is set to min you should get 100K. Some sets used a lot with mechanical range limited to achieve the same thing but it may look a bit weird doing that to a slider.
You're reminding me of a early 70s tube Panasonic I have where 2/3 sliders were wrecked giving no color and no sound, one pot the metal fingers broke off the plastic slide and I drilled and tapped the slide to reattach, the other slide was broken the same way but the fingers were completely missing....I was able to rob the slide portion of the pot from a similar vintage SS Panasonic that was beyond repair.
With enough creativity you can often get around really goofy issues.
Old 03-04-2024, 04:42 PM
Anyone know who sells varicap diodes within the states ? Unless I could try 1n4007 diodes since there is a wide range of frequencies depending on the bias voltage applied in reverse which is what I would need it to do it would be for rf frequency changes in this little tv.
