Old 03-05-2024, 10:26 PM
pac.attack76's Avatar
Stuck in the past
Unknown year General Electric YM-E
25" console powers on. No screen or audio. Just the channel display and gun lights up. No smoke or odor. Also wondering what year this one is.
Genesis does what Nintendon't
Old 03-06-2024, 09:54 AM
Mid to late 70's Look for 4 digit date codes on large parts.
GE is like Zenith. You need to be sure the S-cap is not a white one.
A bad one can blow the HOT, FBT & Vert out.
Look around, it may have a 'mini manual" in there.
Its dead so should be easy to fix.
Old 03-06-2024, 09:59 AM
Per tag. mini manual is on cabinet back. ( if its still there !)
Old 03-06-2024, 10:11 AM
Stuck in the past
That customers service information behind a plastic cover on the back is missing. It shows where it should be stored but not there 😔
Old 03-07-2024, 10:15 AM
Stuck in the past
Where is the s cap located?
Old 03-08-2024, 08:53 AM
Not sure but on the portables its behind the HOT heat sink.
Old 03-08-2024, 10:41 AM
Stuck in the past
I'll look there.
Old 03-09-2024, 03:32 PM
colortrakker colortrakker is offline
Thinking in color...
Man, that's a flashback. Aunt had one of those for 10 years - very similar to this one. Nov. '78 build, and the channel readout was not a real LED. VIR, of course. Guessing this one is a year or two newer.
Good headphones make good neighbors.
Old 03-09-2024, 10:37 PM
rcaman's Avatar
rcaman rcaman is offline
flyback ep77x30 or ep77x33 i believe changed a lot of those. see if the circuit breaker is tripped.
Old 03-10-2024, 09:22 PM
Stuck in the past
If breaker is tripped, would the gun and channel still light? I doubt it but who knows.
Old 03-12-2024, 10:52 PM
Most 60s color sets the breaker was between the B+winding and the B+ rectifiers so if the breaker tripped you'd loose everything except the heaters and dial lamps.
Old 03-13-2024, 10:23 AM
Stuck in the past
Learn something everyday, lol. I'll look for the s cap tomorrow. Supposed to rain so I'll be in most of the day.
Old 03-14-2024, 01:58 PM
Stuck in the past
I checked breaker today and it just pushes in and back out. I've included a pic of its position. I broke my glasses the other day so seeing anything close up is out of the question. Turned set on today and same thing. Just heaters and channel. Turned off for a minute and tried again. This time, I hear it try to start up with kind of a bong sound, but still nothing but heaters and channel, then a foul burning smell so I turned back off. Pulled back but couldn't locate smell origin. I couldn't find the s cap either. I'm including 12 more pics. Hope this helps.
Old 03-14-2024, 02:00 PM
Stuck in the past
More pics....
Old 03-15-2024, 03:28 PM
Went down to the dungeon today. Pulled Sams 1949-1
Breaker on sec of transformer & kills the 143 source. PS is
copy of Zenith with the oil cap
S cap is C702 .00155 mfd 1.5 KV P# EP18X137 Its behind
the HOT & a few inches away.
First checks are
Reset breaker.
Check for @143 VDC at case of HOT
" " " 24 VDC at PGRL5 of the little rectifier ( red wire ) board.
For meter GRD use the CRT grounds.
Burning can be a lot of things. You have to go step by step to narrow things down. Usually the FBT or vert module on these & do it without spending $$$
Zeno
