Old 03-25-2024, 06:13 PM
Emud Model 911 Audio Issues
Greetings everyone, I've been working on an Emud Model 911 for someone and I got the turntable fixed on it for him (that was his main concern with it) but then when I powered it on to try out the turntable I wasn't getting any audio out of the speakers, which I thought was odd because supposedly according to the owner the audio was working fine on it, and I tried it in all of the different modes AM, FM, SW and Phono mode, and there isn't any audio coming from the unit in any of those modes.
I checked the tubes and they all measured well within the good section (over 110 on the emissions test, and at or around 0 for the grid leakage tests).
The thing about this radio is that its supposed to be stereo and it has a audio transformer block on the back with two audio output transformers on it, one wired to each set of speakers (for stereo I would assume.)
Anyways the speakers/output transformers are wired to a 7-pin male tube socket as its connection point to the chassis, and there are two 7-pin female tube sockets on the back of the radio chassis and I tried plugging the speakers into either one of those two sockets on the back of the radio chassis and I'm getting no audio out of either one of those sockets.
I'm not too keen on having to do too much digging around in this set to get it going because as we all know these old German radios are a nightmare to work on, so I wonder if anyone here has any experience with these old Emuds and if so do you know where I should look to start trying to troubleshooting the audio issues I'm having with this radio?
Also the guy I'm working on this for wants this unit done before Memorial Day because he wants to play some of his records on it for a party he's having on Memorial Day.
Any help would be appreciated.
Old 03-25-2024, 08:39 PM
May want to check if you have B+ to the outputs.... Especially if it has an eye tube And that isn't glowing green.
Old 03-26-2024, 12:45 PM
The tuning eye tube is working (it glows a bright green, probably the brightest glowing tuning eye tube I've seen on any of the radios I've worked on that had tuning eye tubes in them), but it doesn't respond to signal changes when tuning across the dial in AM, FM or SW; so I don't think its a B+ issue, unless the B+ issue can only affect the output tubes and none of the other tubes?
Old 05-11-2024, 01:30 PM
OK, So a little update on this radio, I was able to get this thing to put out some audio, but its only coming out of the left channel, and its only coming out of the midradge and tweeter the woofer isn't working at all and the volume had to be cranked up full blast to even hear the audio.
I checked the preamp tubes (the 12AX7s that go before the 6BQ5s as this is a push-pull system) and they were fine (I tested them out in my Zenith Console amplifier) and 12AX7s didn't seem to be the problem.
Next I checked the 6BQ5s and there was nothing wrong with those either (they checked excellent on the tube checker) and just to be on the safe side I subbed in some known good 6BQ5s in my tube stash and still no dice.
Then I thought maybe I should try checking the 6CA4 rectifier tube, and I tested it out on my tube checker (a knight kit unit) and it pegged out the meter on the good side but then I checked the tube for shorts and pin 3 was glowing on the shorts test (it glowed for about 3 seconds and then slowly dimmed out.)
My question is, bringing up the idea that was brought up earlier about the low B+, would a bad or failing rectifier tube cause a symptom like that (low B+)?
Old 05-13-2024, 09:55 AM
Penthode's Avatar
Penthode Penthode is offline
In a situation like this, there are some basic tests I like to perform. First check the voltages around the 6BQ5s. Ensure the plate, screen and control grid voltages are correct. Plate pin 7 and Screen pin 9 should be roughly the same between 200 and 250 volts. Control grid pin 2 bias should be around -8 volts.
If that is okay, inject a signal to the control grid of each 6BQ5. I like to use myself by touching a screwdriver to the control grid and listen for a faint buzz. If you are not used to doing this, you make wish to use another signal source such as capacitively couple the filament supply or a separate signal generator. A two or three volt p-p input shuld provide a noise.
Have you checked the voice coil continuity of the loudspeakers? Or tried connecting a transistor radio output to the speakers?
If the 6BQ5's are okay, then you move back. The cheap coupling capacitors to the control grid of the 6BQ5's are always suspect.
Old 05-14-2024, 02:02 PM
kf4rca kf4rca is offline
Something to check. Sometimes there is a cap across the primary of the output transformer, say a .005, that can short and you will get no output. You will have B+ on the plates, but since there is no potential difference across the primary, you will get no audio. But remember this. If it worked before, it can work again!
Old 07-07-2024, 12:58 AM
The top output transformer has two capacitors going across what I'm assuming is the primary of it, a .1 uF and a .15 uF both at 250 VDC, I wasn't able to test them out to see if they were shorted or not, but I have those caps on order to replace them to see if it fixes it.
But I do know that the 100uF 12VDC electrolytics and the .02 uF 600 VDC paper(?) caps that were going from the 6BQ5/EL84 Sockets to chassis ground were both bad (they both measured open) and when I replaced both of those caps on both of the 6BQ5/EL84 sockets the radio was still not putting out much audio, the volume control still had to be turned up full blast to hear anything.
Old 08-04-2024, 07:26 PM
UPDATE: I got those capacitors on the top of the output transformer replaced and the audio went back to normal (it played at normal volume.)
And I also figured out that there was something weird going on with the "Stereo" Button on the unit because when I would jiggle and repeatedly push the "Stereo" button the audio would also get a lot louder with that button being fiddled around with, and I'm guessing that the button's contacts must be getting worn out because I had sprayed that button down twice with contact cleaner and it still was acting up.
I had the unit working really well (I had the "Stereo" switch jiggled around enough so that the volume was coming out like it was supposed to when the guy came to pick it up and take it home (and pay me for my work) but then when he got it home and hooked it up and tried it out at home it quit working properly again, (which I have a feeling it was that "Stereo" switch that glitched out again), which I tried to explain to him through text message how to manipulate that switch to get the audio to come back again, but it didn't seem to want to work for him like it did for me, so I'm going to have to work on it again for him at some point.
Old 08-07-2024, 09:33 AM
DavGoodlin's Avatar
Motorola Minion
I have needed to repeatedly spray down and attempt to "polish and re-spring" the slider switch contacts on the pushbutton deck. Access can be tricky too.
The EMUD 915 I worked on was just like this. The buttons were creating issues with audio, using all the tone/mono/stereo control permutations, including very flimsy tone pots.
First I hit it with DeOxit D5 then CRC 5-56 or contact cleaner leaving no residue, finally DeOxit one or two more times. Don't neglect the lubrication needed on the mechanism/slider. A Korting switch deck needed even more solvent-rinse-spray-repeat.
German designs are so similar across the makes yet parts quality varies. I felt the EMUD was more solidly built than Grundig and Korting.
-Dave G
Old 08-12-2024, 06:13 PM
Thanks for the info, when I get around to working on that unit for the guy again I think I might try what you suggested, because I thought that maybe just hitting it a couple of times with CRC Contact Cleaner would be enough to repair the switches and controls on this unit, but it looks like I probably should of hit it 4 or 5 times.
