Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > Transistor Portable Televisions
Old 04-27-2024, 03:35 AM
Telecolor 3007's Avatar
I love old stuff
The 1st micro-tv by "Philco"
Long before walk-man tv by "Sony", a company named "Philco" made a micro-tv. Where there any good those sets?
Sailor Moon
Old 04-27-2024, 09:57 AM
WISCOJIM WISCOJIM is offline
I know of no "micro" TVs that Philco ever made.
Could you give us an example of one they actually produced?
Old 04-27-2024, 01:28 PM
kvflyer kvflyer is offline
Sounds like a Philco Safari portable. I have two of them, one is working with absolutely nothing done to it!
Is this what you are referring to?
Old 04-27-2024, 03:13 PM
The Safari is not a "micro-tv" by size, although it does use a small CRT.
Old 04-27-2024, 04:42 PM
I love old stuff
It was micro compared to other sets back then.
Yes, that is the tv.
Sailor Moon
Old 04-27-2024, 06:22 PM
Reliability was good, performance was good, and the unique magnifying mirror in the back makes the 2" CRT appear the same size as a 17" tube at normal viewing distance....If viewing a letterboxee program today you can get a bigger illusions by sitting further back and letting the mask cutoff the letterbox.
Old 04-28-2024, 10:12 AM
Reliability was good, performance was good, and the unique magnifying mirror in the back makes the 3" CRT appear the same size as a 17" tube at normal viewing distance....If viewing a letterboxee program today you can get a bigger illusions by sitting further back and letting the mask cutoff the letterbox.
Tom - I know you know this. It's a 2-inch CRT, the 2EP4.
Old 04-29-2024, 02:50 AM
“ the unique magnifying mirror in the back makes the 2" CRT appear the same size as a 17" tube at normal viewing distance...”
I think you meant 7 inches.
”Micro TV” The term was first used by Sony with their introduction of the model Micro TV 5 303 series in 1962.
Old 04-29-2024, 08:25 PM
17" was not a typo. It's from a review in one of the period electronics magazines. The screen magnifier makes the apparent image size grow as you walk farther back and at the max distance before the opening clips the top and bottom when watching my working set the image appears the same size to me as a period 17" direct view set does at that distance... Its good enough to be a decent living room set from its era if you like to sit a good ways back from it.
Old 04-30-2024, 08:47 PM
I have two working Safari’s, tan and black. I know of the magazine you speak of and when I read that article, I tested my sets and no way did I see 17 inches. More like 7 inches max and you have to be in the sweet spot to see the effect. I will say that when I tested, did not have ability to look across my room. I imagine it would be like looking at a projection hologram trying to find the sweet spot.
Edit: The below link shows one of my Safari’s photographed from about 4.5 feet away. For comparison, the color set is a Sony KV4000 with 3.7 inch screen.
https://visions4netjournal.com/wp-co.../IMG_3892.webp
Old 05-01-2024, 07:24 PM
Your observations at 4.5' track with mine. It's from more like 10-17' where you're on the edge of cropping the image where the full magnification effect is realized...It scales fairly linearly down as you get closer.
Old 05-03-2024, 12:17 PM
At 4.5 feet away, the parallax is so severe that if you move your head slightly in either direction, the image is lost.
Old 05-03-2024, 10:11 PM
I can't remember seeing anything like that. Perhaps it's something that is dependent on different vision characteristics of different viewers.
