Old 06-12-2024, 01:31 PM
rvmeush rvmeush is offline
How to clean white covering of VM record changer
I have an early 1960 Voice of Music record changer that I'm trying to recondition. One particular problem is the yellowing that has discolored the covering on the cabinet. I have attached a picture of the outside of the cabinet and also a portion of the inside which has remained white. I haven't been able to find a good process to fix this problem. I used some Tuff Stuff foam cleaner for car interiors, and it did take off some of the grime but didn't restore the white color. I experimented with Mr. Clean Magic Eraser but that didn't have any noticeable effect. I have seen some suggestions to use Meguiar's Covertible Top Cleaner but wasn't sure it would work any better.
I thought I would check on this for possible good solutions.
Thanks.
Old 06-12-2024, 02:01 PM
I wonder if retrobrite would work on vinyl based portable cabinet upholstery?
