Old 08-21-2024, 04:57 PM
Varicap rating
Is there a way to figure out what pf rating a Varicap is when there is no markings at all. These are for vhf tuning if that helps.
Old 08-21-2024, 06:16 PM
If you have a capacitance meter and a voltmeter, you can rig up a simple circuit to apply a measurable DC voltage to the Varicap while blocking it from the capacitance meter.
https://www.youtube.com/watch?v=D9eRJsswCUk
Old 08-22-2024, 07:36 AM
While A 1 uf cap equals to 1000nf what ceramic cap would be 1000nf.
Old 08-22-2024, 08:09 AM
not sure what you are asking...
ceramic cap @ 1000nf = 1uf code ia 105.
Old 08-23-2024, 09:59 AM
What would a 1nf ceramic cap behave like if it measures 358nf would it possibly still work or not.
Old 08-23-2024, 10:13 AM
clearly not.
If it's really a 1nf cap (0.001uf /1000pf) testing at 358nf, that is way WAY out of tolerance by a factor of 350 times, which is a bit unbelievable, but if true, its very bad, or the test is lying.
Old 08-23-2024, 10:46 AM
What may be allowable 2-250nf to at least work
Old 08-23-2024, 04:19 PM
Is that a mistake? Do you really mean 1uf instead of 1nf?
Old 08-25-2024, 07:10 AM
Will a 68 pf 1kv ceramic work in place of a 68 pf 100volt mica in an rf circuit?
Old 08-25-2024, 10:22 AM
Depends on the ceramic dielectric. NP0 or CG0 will probably work. Anything else probably not
Old 08-25-2024, 10:35 AM
This one is n750 whatever that means
Old 08-25-2024, 11:16 AM
n750 means a capacitance temperature coefficient of negative 750 parts per million per degree C.
This means it was deliberately designed to compensate temperature changes when used with a coil that increases inductance value by 750 parts per million per degree C.
Old 08-25-2024, 11:24 AM
So this cap may not work in a vhf rf circuit
Old 08-25-2024, 08:07 PM
What exactly are we discussing? Started out about a varicap, know talking about a ceramic capacitor.
What is the problem we're trying to solve?
Old 08-25-2024, 08:17 PM
My money is on world domination.
