Old 01-22-2025, 12:19 AM
CRTguy CRTguy is offline
CRT boards smell bad after cleaning off flux, anyone know why?
I recently re-flowed all the solder joints on my 1992 Hitachi CT2043B 20" CRT TV and used a lot of liquid flux to do the job. The solder I used was Chip Quick 63/37 Tin/Lead no-clean solder that I purchased in 2023. The flux I used was Kester 186 Rosin Soldering Flux that I purchased in 2019. Before I did any solder work on the boards, there was never an issue with them smelling during operation. When I re-flowed all the joints, I didn't clean the flux off for a year and during that year, there was a slight flux smell during TV operation but it was barely noticeable.
A few weeks ago, I used several methods to clean the flux of my Hitachi TV boards. First, I cleaned the flux off the bottom and top of the boards with a toothbrush and 91% isopropyl alcohol. I had to also clean the top of the PCBs because some flux still seeped to the top side during soldering and when cleaning the bottom of the board. However, when I did this, my boards had a really strong smell that sort of smelled like the flux I used and gave me a bad headache. I then cleaned the boards a second time using the same toothbrush and alcohol method and it cut the smell in half and the smell no longer gave me a headache. Then I let the boards dry and started using the TV again. After about 30 minutes of TV operation, that same flux like smell filled my small room and it was strong. I had to turn off the TV because of this.
Next step, I obtained some MG Chemicals 4140A flux remover and cleaned my boards using that and a toothbrush and it did nothing to remove the smell during TV operation. I went over the top side of the boards one more time with q-tips and alcohol and was able to clean off a small amount of residual flux that remained but once again, this did nothing to remove the smell of the boards during operation. It sucks because I really like my 20" Hitachi TV and it works perfectly but the smell from the boards during operation becomes so strong that I don't enjoy using the TV when this happens. I even cleaned the boards in my sink twice with soapy water and a toothbrush and rinsed them off well under the faucet and it didn't help. My next step might but to purchase the flux remover called "Flux Off" and see if that does anything.
I think one possible explanation is that some flux got trapped under some components or even inside some components. If that was the case, would there be any way to remove the trapped flux? Is there anything else that could be going on to cause the boards to smell after cleaning? Is it possible that I removed some sort of protective layer off the top of the PCBs and they are now off-gassing? Any input is appreciated.
Old 01-22-2025, 07:15 AM
Even some PCB have some characteristic smell.
For non-SMD boards I wash using paint solvent ("thinner"). Makes good against normal solder flux. Caution for not spilling it ont eg. styroflex caps, since it is aggressive.
Old 01-22-2025, 07:21 AM
The method I prefer for washing: I put the board in vertical plane, for not accumulating dirt and even the thinner.
Old 01-22-2025, 07:30 PM
vol.2's Avatar
vol.2 vol.2 is offline
I would quite while you're ahead. Every time you try to clean it with more chemicals, you add to the smell.
Best solution is to just let it bake until the smell fades. The heat is what's causing it to off-gas, so eventually it will run out of fuel.
If it's really that horrible, turn it on and stick it in the garage overnight or out back if the weather's okay.
Old 01-23-2025, 02:41 PM
No brush needed, fumes only when wet, and very mild!
https://mgchemicals.com/products/sol...for-pc-boards/
91% IPA if I run out - and sparingly, as I use Kester 44, so no added flux needed. Same stuff all micro-min soldering shops used in the Navy.....Kester 44 in .031 and .020, i also have some older Kester 33 in .031 and .062
https://www.amazon.com/Kester-24-633...149K4JTY&psc=1
USN RET 22YRS (Avionics/Cal)
Old 01-23-2025, 06:51 PM
A lot late 60's boards (especially Panasonic) were coated with white shellac after all the soldering was done so the copper traces stayed bright.
I agree with vol 2. Turn it on and let it run. It will gradually clear.
Old 01-27-2025, 01:31 AM
I had always used Kester 44 for soldering and it works great but I ran out and made the mistake of buying the much cheaper Chip Quik solder which works but needs added flux to make a good joint. The Chip Quik solder is what I used to re-flow the joints on my Hitachi boards and why I had so much flux to clean off because I had to add so much flux. Going along with what you said, I never needed to add flux to Kester 44 to make a good joint.
I also used the non aerosol version (4140A) of the MG Chemicals flux remover you linked to, to clean my TV boards. The product page claims it's low odor but it has a terribly strong odor that lingers for hours in the room it's used in. Using it outside wouldn't be an issue but I had to use it indoors recently because of the snow.
Old 01-27-2025, 01:36 AM
It turns out you're right. I used my Hitachi TV for a few hours yesterday and the smell was much less noticeable. I hadn't used the TV in about 2 weeks. Also, I do believe that what I'm smelling is not the flux I used and actually the board itself.
