Old 04-15-2025, 03:11 PM
Dropping resistor
I’m looking to drop a 9 volt battery to 3.5 volts around 1 amp load momentarily with a resistor. Does anyone know how to do this math ? Or a 7805 regulator but I don’t know if it can go down to 3.5v.
Old 04-15-2025, 03:57 PM
Google ohm's law. Put the resistors in series with the load....also calculate watrage V x I.
That regulator can't go that low. You'd need a LM317 or LM337 for that.
Old 04-15-2025, 04:28 PM
1) How accurate does the 3.5 volts need to be?
2) An ordinary alkaline 9V battery cannot supply 1 Ampere without dropping voltage drastically and rather unpredictably. It might even be below 3.5 volts at such a high current. You need to find a heftier source.
https://www.youtube.com/watch?v=rG2ozSOvxBY&t=3s
Old 04-15-2025, 04:33 PM
Forget the 1 amp it’s probably 500ma and the voltage around 3-3.5 volts
Old 04-15-2025, 08:15 PM
You can see from the video that 500 mA is still going to be too much for reliable operation.
Old 04-21-2025, 06:15 PM
Allison Rae's Avatar
Allison Rae Allison Rae is offline
A LM7805 with 2 to 3 silicon rectifiers(most of these are a 0.5V drop) in series on the output-should get you in the ball park of the 3.5 VDC. As for the current, how long do you need the 0.5 amp for. A capacitor discharge circuit might get you the surge current you require.
Old 04-22-2025, 03:21 AM
TV-collector's Avatar
TV-collector TV-collector is offline
Lightbulb
Hi Timmy,
Here is what you need:
https://www.ne555.it/category/schemi/alimentatori/
I think just this one will fit:
https://www.ne555.it/alimentatore-sw...-3v/#more-3804
Best regards,
TV-collector
Scotty, beam me up, there is no more 4/3 Television and AM radio in Germany!
Old 04-22-2025, 08:12 AM
kf4rca kf4rca is offline
Next question: does it need to be filtered and how well?
