Old 05-01-2025, 11:17 AM
oldtvman's Avatar
oldtvman oldtvman is offline
Larry Melton (oldtvman)
Another RCA service bulletin on the CTC 5
https://antiqueradios.com/forums/viewtopic.php?t=157835
[IMG]
Old 05-01-2025, 11:21 AM
oldtvman's Avatar
The importance of factory service bulletins
During my many years of owning a large factory service center, no tool was quite as helpful as factory service bulletins. I submitted a couple, but having them saved time and a lot of headaches.
[IMG]
Old 05-01-2025, 10:12 PM
Hmm, that post on ARF is from 2011. I think I probably read it then; I know a contrast/brightness modification for the CTC-5 was a well-known improvement "back in the early days". That must be the one. Thank you for posting it here.
Old 05-02-2025, 10:50 AM
DavGoodlin's Avatar
Motorola Minion
In a similar way starting with CTC12 chassis, RCA tied the CRT cathode bias to the shunt regulator grid.
This allowed shunt regulator to be cut-off during extremely bright scenes, regulate only during darker material to maintain load on HV supply.
It seemed to reduce a "blooming" issue with a CTC11, was tough to mitigate with just HV, brightness/contrast controls.
-Dave G
