Old 06-14-2025, 06:58 PM
Doug Doug is offline
Insignia ns32b2327b00d95 tv Anyone know if this best buy brand comes apart? l
Took all screws out,and wall mounting bracket, even lifted up.back labels looking for hidden screws
Set is1 1/2 yrs old no picture..led flashingb5 times so I want to.look at the power supply board.
Old 06-15-2025, 05:37 PM
Sometimes the back panel has plastic clips that hook in at the edges where the front and back meet (like most remotes) and you have to pry them apart...
Old 06-15-2025, 07:11 PM
I did get it apart
set has sound no picture.
there is 58v at the led dive connector. this set has 10 leds back lighting
none come on. I assume the 58v is correct
appreciate the reply
Old 06-16-2025, 12:49 PM
Zenith26kc20's Avatar
Could have a bad LED. Most are series wired and if one goes bad, they all go out.
Old 06-19-2025, 07:09 AM
kf4rca kf4rca is offline
Yep, LED. Since the LEDs are a high failure item, I'm surprised the manufacturers didn't make them more service-able.
You may have more than one defective. What happens is one shorts out, the current goes higher and then burns out another one.
I've developed a new fondness for CCFL sets.
