Old 10-09-2025, 08:59 PM
pac.attack76's Avatar
Stuck in the past
Vizio D50-F1 backlight dead
Is the led strips most likely suspect or the board that controls them. Can faintly see image on screen.
Genesis does what Nintendon't
Old 10-10-2025, 07:27 AM
kf4rca kf4rca is offline
If you've got voltage going up to the panel, yes, its most likely an open LED. Probably 2 LEDs are bad. One will be shorted and one will be open.
Old 10-10-2025, 08:19 AM
Stuck in the past
Ok I'll check it out, ty.
