Old 11-21-2025, 01:08 PM
soliman15's Avatar
soliman15 soliman15 is offline
Emerson 612 Grid bias problem
Hello, I'm working on Emerson 612 TV and found that audio is weak and the image contrast is not that good, after troubleshooting I found that the grid bias in final stages of both audio and video is lower than what the Sam's shows, in spite of having the correct B- voltage. The attached images have the Sam's voltages in black and the measured ones in red.
is this the reason for my TV poor performance and how can I fix it. thank you
Emerson 611
Old 11-21-2025, 01:38 PM
Have you replaced the tubes?
Old 11-21-2025, 01:50 PM
Kevin Kuehn's Avatar
Workin' Late Again
On your audio picture I don't see where on the Sams info you're getting the -8.4v you have designated in black? I think -8.4 is in error, and there's likely a problem with some component/components in the negative supply line. Also the focus control is part of that circuit, so I suspect that negative bias could change some when you alter your focus setting.
Old 11-21-2025, 01:53 PM
What kind of meter are you using?
Old 11-21-2025, 01:55 PM
Agree on possible error in the SAMS.
Old 11-21-2025, 02:20 PM
Workin' Late Again
OK now I do see -8.4 listed on the voltage chart for pin 6(no internal connection) of the 6v6. So -8v seems within tolerance for that audio output tube. So if we assume -8.4 is the negative supply, then that should be divided by the in series 33 and 180 ohm resistors feeding the grid of the first video amp. So the measured -1.4v makes more sense to me than -.2v, unless Sams -.2v measurement was taken with a lot of grid leak action from a very strong signal, but I have my doubts about it changing that much when it has a fixed bias through a 470k at the grid.
Old 11-21-2025, 02:25 PM
soliman15's Avatar
I did swap the tubes but nothing has changed.
I measured -8.4 on pin 6 of the 6v6 tube which is not connected inside the tube but used as tie point and is driven from the B- via voltage divider and it is in the Sam's (attached). I agree Sam's it could be wrong and the -8.4 should be ~-3v
Emerson 611
Old 11-21-2025, 02:36 PM
Workin' Late Again
Actually I looked at the specs for a 6V6 in my RCA tube manual and it says -8.4v on the grid with 180v plate supply for class A. So I think Sams -2.4v is the error.
Old 11-21-2025, 06:45 PM
soliman15's Avatar
Interesting, I'll do further troubleshooting and see if I can find any other issues.
Emerson 611
Old 11-21-2025, 07:47 PM
With NO signal you should get strong , clean snow & a loud "water falls" from the audio. If you dont look tward the tuner, IF, or AGC. Could be 2 problems but thats rare.
Old 11-22-2025, 03:58 PM
soliman15's Avatar
Apologies, just found another voltage chart in "Beitman Most Often Needed 1950 Television Information" and it is almost what I have, so I'm back to alignment which I really don't want to do ):
Emerson 611
Old 11-22-2025, 04:58 PM
Workin' Late Again
Have you looked at your AGC voltage on pin 2 of the video detector to see that it changes with signal strength?
Old 11-22-2025, 08:11 PM
Penthode's Avatar
Penthode Penthode is offline
Does the schematic indicated what the ohms/volt of the meter is? In the days before digital multimeters and even VTVMs, a meter was typically 20,000 ohms per volt. That may account for the less negative grid bias.
Old 11-22-2025, 08:12 PM
Penthode's Avatar
Low gain in the audio and video simultaneously could be on the IF or RF stages. First thing to do is to test the tubes.
Old 11-22-2025, 10:29 PM
"Back to" alignment? If so, that's the last thing in the world you should be doing.
