Old 12-22-2025, 03:55 PM
TinCanAlley's Avatar
Avante On/Off issue
Here's an odd one and I'm not sure where to start.....
Months ago I turned off the SC (which I believe is short for Space Command) thinking it would turn off the heater in the CRT, but found out it didn't. I left it that way and was turning it off and on by pressing the small button under the door. With off, there was no on/off, volume or channel selection. This was fine for awhile, but I decided to turn it back on. Now the remote will change volume and channel, but not on/off the set. So I pushed the button on the panel and it didn't turn off the set. I switched the SC back off, but the button still won't turn the set off. I unplugged the set and upon plugging back in, the set is on. No matter what position the switch is in, I can't turn the set off.
Anyone familiar with this circuit? I'm sure there's nothing fancy about it and maybe the SC switch is going bad and not activating the power button on the front panel?
Anyway, I'm going to dig into the SM, but was hoping the brain power here could shorten my search.
Thanks!
Old 12-22-2025, 04:31 PM
Could it be this simple? I'm guessing not as nothing ever is, but you never know. According to the SM, it's a ceramic capacitor. I wish there were all the electronic places around now as they were when I was younger. I could be out and back with it in less than 30 minutes. Now I have to order and pay shipping. Need to keep a running list of components I want/need so when times like this come up, I have a full order to make it a bit less painful.
Old 12-22-2025, 04:42 PM
vol.2's Avatar
vol.2 vol.2 is offline
I keep a big box full of old PCB ewaste for this. Usually can just find something in there if it's just a onesie-twosie.
A .01uf ceramic will say 103 on it. Very, very common on lots of boards. Should be able to use a film or lytic there as long as it's 100V.
Old 12-23-2025, 09:15 AM
Depending on where it is in the circuit it could just be an optional snubber/spark suppression cap and you might be able to run with it disconnected. Some space command CCIIs have a solid state power switch that can short or open.
Chromacolor IIs almost always have instant on for the CRT and almost never allow you to switch it off. 2 solutions to that are unhook one of the instant on transformer wires, or unplug the set when not in use.
Old 12-23-2025, 12:26 PM
There is a post about the trac. I would look there
for starters. My serch dont work or I would look. Probably a yr or 2 back.
Zeno
Old 12-28-2025, 03:17 PM
Now I am upset I didn't keep more boards from scrapped equipment.
Old 12-28-2025, 03:21 PM
I am currently unplugging when not in use, but there are some other issues that seem to be part of the circuit. When I plug it in, the image is unstable, but tapping the power switch clears it up. Seems to also cause vertical hold issues until tapped. So it would seem I need to try replacing the capacitor in hopes it clears it up. If not, I need to find the entire circuit and find the fault.
Zeno
What, exactly, should I be searching for?
Old 12-28-2025, 04:40 PM
Zeno
Okay, I think I found the thread(s) you are referring to. The service manual didn't have the remote control board in it, but I found an addendum that does, so I found the board in a pic I took years ago and will have to remove the board and replace the capacitor noted in the troubleshooting PDF. If that doesn't work, can someone explain the triac and if that's something replaceable, or is it no longer available.
Old 01-09-2026, 11:30 AM
I pulled the 2 ceramic capacitors off the remote control board and tested them. Both are .01uf 100V. The markings on them are AVX .01 Z 100V. When tested, one is 7.8 and the other 8.1. The new capacitors read 10.1 and 10.2. Is it safe to assume the Z on the OEMs means they have a tolerance of +80 and -20%? If that's the case, the OEMs are about 20% out of spec, but does that mean replacement was/is necessary? Is there some other test I can do on them?
I know the best thing is just to change them, but I'm trying to add to my knowledge and make sure I understand and am doing things correctly. That and I want to make sure it's fixed before reinstalling.
Old 01-09-2026, 03:08 PM
No joy. I replaced capacitors as noted in the troubleshooting PDF and it didn't work. Set still needs to be unplugged. When in auto mode, I can change channels, sometimes volume and never power. In manual mode, when I plug it in, it is on, but the screen is wobbly until I tap the power button. It is then stable, but if I tap it again, it wobbles. So I think it is trying to remove power, but can't successfully and that's the wobble? I'm not sure what else to try. I want remote usage, so fixing would be nice.
On the bright side, the volume control is now clean and working as it should and so are all the other pots for color, tint, etc. Wasn't a complete waste of time.
If anyone has any suggestions on what to test on the remote board, please let me know.
Old 01-09-2026, 05:37 PM
I don't know how I missed this, but there is another "fix" in the troubleshooting PDF. It seems more likely as on/off is erratic as sometimes it turns on or off from the button and in auto, the volume doesn't change with the remote. I'm attaching the "fix" and the part of the schematic. They seem to be 22uf/10V. I have those as well as the two 10uf/16V. Since I'll be doing those, I'll need to get a 220uf/50V as well since I should replace all electrolytics.
Old 01-10-2026, 01:25 PM
So I have two more questions. The two 10uf capacitors I have are non-polarized. Going by the schematic (attached) it seems they go to ground. Can bipolar be used in this way?
Also, I just noticed from the pics I took of the tuner assembly where the remote control board is mounted, it seems the remote board has either been modified by the factory or afterwards. In the pic I see what appears to be an axial capacitor with yellow lead covers and something with 2 screws in it. Also, the paste from the triac is all over the place. I know I didn't do that while removing it as I would have noticed that stuff on my hands. Anyone ever see something like this? Can't be a bypass as it was working with the remote. There is an axial capacitor on the board just past the triac, but it is a 2uf/15V and the size of what's in the pic would have to be a much larger value going by its size.
Old 01-10-2026, 02:18 PM
Well while I didn't fix the remote control issue, I did manage to fix another issue that has bugged me for years. I no longer have jailbars! In the past I changed the diodes on the HOT and around the horizontal circuit as well as replacing the horizontal module. Nothing worked. So it is one of two things I did in this latest repair attempt. It is either the cleaning of all the control pots or rerouting the convergent board wires to more match what I saw in a pic from another set. Either way, they are gone!
But of course this can't be without another issue. Seems the the rerouting of the wires has thrown off convergence as it is has noticeably gotten worse on the right side and top as well as, to a lesser degree, around the entire image. I also am noticing color blotches around the bottom left corner and the right edges. Could this be a color purity issue or maybe it needs to be degaussed? If it needs degassing, how can I do that without a degasser?
I also think I need to readjust focus as the moire effect is more noticeable.
I'm attaching an image of the screen showing the lack of jailbars and you can kind of make out the color blotches.
Old 01-11-2026, 07:34 AM
Adam's Avatar
Adam Adam is offline
Mine wouldn't turn on -- this is the thread about it: https://www.videokarma.org/showthread.php?t=276998
And here's some information I found about how this circuit works - from TAB books - Zenith Color TV Service Manual - volume 3.
