Old 03-05-2026, 03:12 PM
LMELTON's Avatar
LMELTON LMELTON is offline
CTC 5 tale of two tv's?
As you know I have a CTC 5A, I'm starting to restore. The interesting issue is I used co-pilot to source a couple of parts, and it responded by saying that the early model 5's were the Super models instead of the deluxe models were you guys aware of this info?
Old 03-05-2026, 03:51 PM
Yes, my CTC-5D is a Super. I think the later Deluxe used the CTC-5N chassis. It is different enough that Sams put out a separate Photofact.
Old 03-05-2026, 07:56 PM
My Chandler CTC-5 Deluxe uses the CTC-5U chassis.
Wish you well on the restoration and hope you will chronicle the process.
Old 03-10-2026, 02:23 PM
DavGoodlin's Avatar
Motorola Minion
Let us know progress and if you need any parts. I have a CTC5D and CTC5N spare chassis, each for a Whitby(deluxe) and Aldrich (special) most parts requests are then found out Moyers, Sunbury PA has many NOS RCA parts, so I never parted them out.
-Dave G
Old 03-12-2026, 05:25 PM
LMELTON's Avatar
thanks, hopefully I have what I need, I was service manager for an RCA parts distributor in South bend, plus I the inventory from one of the older Rca dealers in the area.
