Old 04-29-2026, 05:39 AM
harry dalek harry dalek is offline
MY updated video card television systems converter
Television systems converter
Well it took 23 gos to at least be happy enough to show my simple Linux version please read instructions give you an idea how to run the program. It needs to have some things already installed but it will install whats missing so run the sh file click right on it and select run as program ..i find the first convert takes a few sec's and always revert when finished or it wil be stuck in the first system you converted to on revert but a reboot always resets the display 1 to original settings unlike windows where you are suck till you reinstall the OS if you make a mistake with the old modelines . So its no real problem if you make a mistake with this one the worst case a reboot fixes all . I am not sure how display 1 will go with other monitors as i tend to just view the results on my CRT display 1 and it tends to go off so i hardly use it infact i could pretty much switch off that LCD and how it works perhaps depends on what you have mine just gos off most of the time which is understandable being fed most of the time but television standards which it will not be happy displaying, it should pop back on with revert swapping back to its original display system . thats why you should not forget to reverrt the first time ! as i said if you did just reboot and remember next time ;0 )
https://www.facebook.com/groups/1705...70282230246247
https://www.vintage-radio.net/forum/...d.php?t=226451
File Type: jpg 678977096_10243917537573478_7852883835535337484_n.jpg (29.8 KB, 13 views)
