Old 06-13-2026, 05:26 AM
BRC2000 BRC2000 is offline
This is a very longshot l need help with my Magnavox T991-01.
This TV was born in Greeneville Tennessee U.S.A. on May 1977 l do not know how it got to London UK still in its packing box?
It looked new when unpacked all the user controls were jammed with grease which had to be cleaned out and replaced.
When powered it worked the only thing wrong was pincushion distortion which was Q7.
It has worked for about ten years (not daily use) OK until Q5 Q6 went short circuit .
The C.R.T.is still good and the TV looks like new and l would like to get it working again.
These transistors only have part numbers l have tried MJE340 and BU426 it works but the BU426 gets much too hot after a very short time!
l hope some one remembers these TVs and can suggest replacement parts or a fault in the power in the power supply which would
cause this problem.
Thankyou
Keith (BRC2000)
Old 06-13-2026, 12:37 PM
damen's Avatar
damen damen is offline
cause this problem.
Thankyou
Keith (BRC2000)
We used the horizontal output transistos we carried on service calls for Q6. Sams lists ECG-165 for Q6, and ECG-186 for Q5.
Old 06-13-2026, 12:39 PM
damen's Avatar
Overheating of the transistors was usually caused by bad solder connections of the pins on the mainboard that the module plugs onto.
Old 06-13-2026, 12:41 PM
damen's Avatar
When it was necessary to replace a burned up module, the replacements came with a warning note to resolder these connections before operating the replacement module.
Old 06-19-2026, 04:01 AM
Hi DAMAN
Thank you for your help I have checked the base board pins and they are OK.
I looked up the spec for the two transistors you suggested and found BU208A and BD139 are a close match and both are working OK.
Thank you
Keith (brc2000)
