Old 07-13-2026, 07:59 AM
Radio Dave Radio Dave is offline
Admiral 30B15 set
Hi,
I've got a 1949 Admiral 30B15 television set that I've been working on for a few weeks. It currently has no high voltage and no sound, but all the tubes light up.
It has a handful of problems, and I'm taking them two-by-two as I work through the chassis. Current items:
  • Some mice chewed through these power resistors (shown in attached photo)
  • The electrolytic filter caps are leaking
Any recommendations for replacement power resistors?
Old 07-13-2026, 11:32 AM
They don't need to be anything special. Make sure you meet or exceed the original wattage rating.
Here's one I did a while back using a cheap cement wirewound type for the higher power one. A smaller wattage wirewound for the other.
Old 07-14-2026, 09:28 AM
Thanks. I want to verify that I've read the parts list correctly. From Rider, is the one on the left R329, 15W; and the one on the right is R330?
I traced the wiring and found the right-side resistor connects to pin 3 of the 6V6GT, the horiz oscillator.
Old 07-14-2026, 04:12 PM
Yes, R329 and R330
