Old 07-14-2026, 12:03 PM
Chris K Chris K is offline
Back with a 630-TS Problem
Hi all. Good to be back. Life got really, really "lifeie". Re-configured the shop as well. Just got overwhelmed with TVs, parts and junk.
I'm working on the granddaddy of post war RCA TVs. The horizontal is completely unstable, "twitching" almost like something is intermittently arcing although I can't hear or see anything. It won't lock. C168 on the phase can, value 153, has been replaced in fact, EVERYTHING in the horizontal circuit has been replaced. I guess the first thing I should do is check for cold joints. All the tubes in the horizontal circuit have been replaced multiple times with known good tubes. Any suggestions as to where I should start?
BTW, just for anyone who remembers my issue with the T-65, KCS47 and the bent hourglass sides, it was the yoke swap I did. The original yokes are back in place and it's got a rectangular picture. Not magnetized.
Old 07-14-2026, 01:16 PM
The synchrolock circuit is a very fussy beast to tame!
When it works, it works very well, but when it misbehaves, It's a real bitch! :/
Old 07-14-2026, 01:36 PM
Yeah I can't even get a solid sawtooth for the horizontal frequency. I can get it to 15.75 KHz then it jumps all over the place and the trace goes haywire then it holds for half a second etc. Like I said, it strikes me that it might be an intermittent connection although all the coils ohm out so I think cold solder joints is where I should start.
Old 07-14-2026, 05:18 PM
No experience with the synchrolock circuit, so can only make ignorant comments:
1) I'd look for cold solder joints too, but not expect to find any if I had replaced all the parts
2a) Any possibility of having a replaced part value with the decimal point in the wrong place?
2b) Does anyone know of parts value mistakes in schematics depending on the source?
Edit: 3) is there a way to break the loop (like grounding the phase detector output) to see if the oscillator is stable or jumps around by itself?
Old 07-14-2026, 10:10 PM
There's an EXACT adjustment for the adjustment for the horz osc, in the SAMS, was that followed?
Old 07-14-2026, 10:46 PM
DavGoodlin's Avatar
Motorola Minion
I have a similar issue with a 630 TS horizontal sync pulse getting lost before going to the oscillator.
Been sitting for months waiting for a fix after complete recap.
I'm working on it for another VK member who has a Philco 65 roundie for me as compensation.
First step is to check your work, one cap off by factor of 10 or to wrong spot can cause mayhem and we all have done it.
Synchro-guide is explained in RCA literature (can supply some if needed) and re-reading it may help both of us.
I'm enlightened by Wayne's last comment above; grounding a feedback loop can give a clue if oscillator itself has good output waveshape, part of adjustment procedure noted. (have a scope?) This may help uncover source of unstable operation.
-Dave G
Old 07-15-2026, 10:53 AM
Yes I followed that procedure. The issue is the jumping and not the frequency. As far as any of the instructions saying "pull in the picture untill..." that's not possible. The trace is a 15.75 khz sawtooth for a half second and then nonsense then back to a sawtooth then....
I wish there was a way to post video on VK. It would clearly demonstrate the fault.
Old 07-15-2026, 11:00 AM
I have checked my work but in a comprehensive solder check, I can confirm the values once again. I have the RCA service guide for this TV but I don't think it describes the Synchro-guide operation. It would be awesome if you shared it!
I have 4 scopes so I think we will be OK! I've tried 4 different oscillator tubes in this including ones that work in other TVs.
The socket for the sync discriminator (V123), the 6AL5 needed to be replaced. I've checked the work multiple times but I'll do it again.
Old 07-15-2026, 12:57 PM
Here is the circuit. Could the 6AC7 and associated components possibly be the problem? Ive switched it out with 2 different tubes and I pretty sure the pins are tight in the socket.
Old 07-15-2026, 09:29 PM
The schematic says the grid of the 6AC7(pin 4) is -2 volts.
I don't think it would hurt to temporarily ground it, so I'd try the following:
1) put a scope or meter on pin 4 and see if it jumps around when the bad waveform occurs
2) if it is jumping with things normally connected, it could be caused by anything from the discriminator to the oscillator because they are all in the loop. I suspect you will see it jumping around.
3) ground pin 4 so the control voltage is constant = zero. Hopefully this only throws the frequency off some.
If the oscillator is now stable, you have isolated the problem to the discriminator. If the oscillator is not stable, the problem is in the control tube or oscillator.
Another thought - with set off, pull the Horisontal Oscillator (6K6-GT) and measure the resistance from pin 5 (R196/C172), looking for intermittent while adjusting Horizontal hold.
Old 07-15-2026, 10:16 PM
All great ideas. I’ll try them tomorrow and post when I’m finished. Thank you!
Old 07-16-2026, 11:00 AM
From what I remember, these sets hate dirty video, if after following old_tv_nut's steps does not find any faults, one thing you may want to try is to feed in composite video, which can be done by removing the 4th pix if (v113) and feeding in video ( capacitor coupled) to the grid of the 1st video amp, pin 1, v115, and see if the h-lock is more stable.
Old 07-16-2026, 12:18 PM
Looks like I'm going to have a busy night when I get home!!!
Old 07-16-2026, 03:34 PM
OK an update. Twitch is gone. Reflowed all of the solder joints and I must have had a cold joint or joints somewhere. Horizontal frequency is good. The problem remaining is lack of horizontal lock. Vertical is rock solid but the best I can do with the horizontal is a very tenuous steady picture that starts to roll after about 4-5 seconds. Even when it's stable, it's not really stable. I can see it moving just a bit before it loses it. I don't know if this means anything but any sort of movement of the focus (not worried about focus...using the electrostatic 5" test tube) or contrast and brightness throws the horizontal off. The horizontal hold is more or less in the middle but once it loses lock it's very bad. I still couldn't attempt anything like the horizontal adjustments in the service data as they require a semi-stable picture. So it has to be an issue in this Synchro-lock circuit I guess. Any ideas other than some of the ones mentioned before? Should I check voltages on these horizontal circuit tubes???
Old 07-16-2026, 04:59 PM
The Rider service info has an explanation of the horizontal circuits with a couple of drawings of the waveforms in the sync discriminator. You might try looking for them.
