Old 08-09-2026, 02:41 PM
pac.attack76's Avatar
Stuck in the past
August 1977 RCA Colortrak Model GB 704 L
Looks like someone wrote on the back, CTC90D. Anyway, just got this from a guy that was a tv tech who had kept up maintenance for years. It doesn't have any color to it and it has a bit of convergence issue near top. Just looking where to begin. Want to use this set with matching vcr, ced unit and atari.
Genesis does what Nintendon't
Old 08-11-2026, 09:38 AM
Stuck in the past
I've been looking at this for a bit. Due to the move from where I picked it up, an hour away, the yoke had slid back and shifted also causing the purity rings to get pushed back to the socket. I've put everything back up where it should be but I still have nearly no color and convergence is a little off.
Old 08-11-2026, 10:01 AM
vol.2's Avatar
vol.2 vol.2 is offline
Maybe there's an issue with the color control? I would pull it and check resistance across the pot and make sure it's not flaky.
Old 08-11-2026, 10:04 AM
Stuck in the past
The dial at the front behind the door?
Old 08-11-2026, 12:11 PM
vol.2's Avatar
I'm not familiar with you're specific set, but there should be a color control on it. When you turn the color down all the way, it should make the image black and white. It essentially is there to let you adjust the chroma subcarrier level.
If there was something wrong with the control, like there was a break in the carbon track, or it was just really dirty, or there was a bad solder joint or something, that could cause a loss of color like you are seeing.
Another thing that could cause loss of color is if the the tuning is off and you are using RF. Sometimes if the tuning capacitors are dirty, that can cause weird effects like loss of color. That generally just requires spraying the tuner and moving it back and forth a bunch. This would only be an issue if you're using RF input, not if you're using composite.
There's plenty of other possible issue though. It could be a bad component in the chroma demodulation section or a bad power supply source voltage for one of those areas. I'm just giving you low hanging fruit to test
Old 08-11-2026, 06:35 PM
Stuck in the past
Ill check into it. I really don't know at this point. I dont even see tuning. There's only a coax and 2 sets of screws.
Old 08-11-2026, 06:56 PM
damen's Avatar
damen damen is offline
I believe the black plastic piece around the channel knob comes off for access to the fine tuning pots.
Old 08-11-2026, 07:53 PM
Stuck in the past
Wow, awesome!! That was hidden well.
Old 08-11-2026, 08:08 PM
Stuck in the past
No changes with tuning.
Old 08-11-2026, 09:53 PM
vol.2's Avatar
Open up the door at the bottom of that panel and take a picture of the color control. Make the picture larger. Your other pics are too small.
Old 08-12-2026, 07:27 AM
Stuck in the past
Old 08-12-2026, 09:43 AM
vol.2's Avatar
That's it. What happens to the image when you swing that color pot from end to end? Nothing at all?
The color pot is the one on the top right just to be clear.
Old 08-12-2026, 07:24 PM
Stuck in the past
Yeah no change at all.
Old 08-13-2026, 12:44 PM
vol.2's Avatar
In that case, I would remove the control from the circuit and test it for continuity with a DMM.
If you can rule out that the control as a problem, then you can focus on other things.
Assuming the control is okay, then my next step would be to check from the chroma signal out of the demodulation area. I personally wouldn't attempt it without a schematic though
There are other guys on this forum who might be able to point you at some part to check after that or not, but it's going to get increasingly more complex as you rule out low hanging fruit like a bad control
Old 08-13-2026, 05:05 PM
Stuck in the past
You mean that top left looking from the back? Also looks like its had a history with color problems. Some changed the board out and left the old one inside...
