Old 01-20-2005, 07:21 PM
devoid's Avatar
devoid devoid is offline
NA Volvos and Amplifiers
Need a schemo for...
A Telefunken Govotte 5353. Or something similar. After it's on for 15 minutes or so the soung drops way down. Seems to be in the audio amp section as when I turn up the volume it crackles loudly. Tried circuit chiller on many suspect parts with no success. Also if you turn the radio off for 5 seconds and then back on it play normally for a few minutes before going down again.
Old 01-20-2005, 07:22 PM
devoid's Avatar
Opps! I meant "Gavotte".
Old 01-20-2005, 07:51 PM
Tom Bavis's Avatar
Audiophool
I see Tele "Gavotte 7" in Sams #399 - closest one listed. But there are 16 listed at radiomuseum.org - check the pictures there.
Old 01-20-2005, 07:58 PM
devoid's Avatar
Asside from a schematic does any one have any ideas what I can look for? I can't find much on the web thus far.
Old 01-21-2005, 06:51 AM
Chad Hauris's Avatar
I would replace paper caps in the radio if it uses them...then, you may want to try feeding an external signal into the audio amp stage (like from a portable radio...use a .047 600 volt cap in hot lead from headphone jack, ground of jack to radio ground....use isolation transformer on radio if "hot chassis".)
With the external signal connected to the volume control and the Telefunken tuner stage tuned off station, listen to see if the signal from the external radio drops out...this will confirm problem is in audio section.
Another possibility is bad capacitors inside IF transformers....but using the external signal test will divide the set up as far as a likely trouble source.
Does the radio use pushbuttons for mode selection...have you cleaned the switch contacts and volume/tone controls?
Chad Hauris
