Old 03-25-2005, 08:14 PM
Donny's Avatar
Donny Donny is offline
Lets be bad guys.
powering up is it a bad idea?
the wires look ok,nothing smells burnt,so I'm thinking put a cord on it and try it out btw the radio is the damaged one from epay.
Old 03-25-2005, 08:25 PM
outlawmws's Avatar
outlawmws outlawmws is offline
On the Run
Set up a dim bulb tester to cut the power down and allow the caps a chance to reform.
That is simply a light bulb in series with the radio to act as a limit resistor. start with like a 25 watt bulb, go to 60 or so, then 100. It's a cheap thing to rig, and will give the radio a fighting chance. (I know that sounds backwards, but thats the way it works out.)
- Outlaw
Main: 9090DB, Snell Type EIII's, Marantz 6100, TEAC PD-D2500
LR: Motorola tubes, EL84 outputs, , Dual 1019 TT, Sony CDP-CE105, Wharfedale Sapphire SP-89's and a 15" GV center in an infinite baffle
Home Office: Sansui 6060, Sony CDP-C305, Original Advents
Old 03-25-2005, 09:03 PM
Fisherdude's Avatar
Fisherdude Fisherdude is offline
The Golden Age of Hi-Fi
The burning smells start AFTER you plug it in!!
Not worth the risk. Take outlawms' advice, or else buy a variac off ebay.
Or, just replace all the capacitors before you plug it in.
I may be growing older, but I refuse to grow up.
Old 03-26-2005, 06:36 AM
Donny's Avatar
Lets be bad guys.
yeah a light bulb set up and maybe a switch for fast cut off is a good idea
Old 04-08-2005, 09:57 AM
xwarp's Avatar
xwarp xwarp is offline
use the dim bulb setup and turn it on if you must.
this is what i do:
plug the radio in with a 100 watt bulb just long enough to see if it gets any reception. if there is reception, then i start a complete recap. i wait for the reception so that i can repair any oscillator problems with the recap.
Old 04-12-2005, 11:46 PM
newtvdude
Guest
Posts: n/a
variac doodle doo...
I just purchased my first variac. It is a panel mount one without the case. It only has the five connectors on the front and no schematic. I got it cheap, so I would like to use it. Any suggestions out there??? Basically it looks like a large variable resistor!
I heard that I need an "isolation transformer" as well.
Old 04-13-2005, 11:35 AM
xwarp's Avatar
if it is a "powerstat" brand autotransformer type 21, this connections will be this:
for counter clockwise knob rotation:
terminal 4,5 = voltage input
terminal 1, 3 = voltage output
for clockwise knob rotation:
terminal 1,2 = voltage input
terminal 3,4 = voltage output
bill
edit: yes, an isolation transformer is good too.
Old 04-14-2005, 10:59 AM
newtvdude
Guest
Posts: n/a
Yup! That's it. Thank you very much for the helpfull info on the terminals! I just purchased the transformer for $10 so I should have it up and running in no time. Yes, it is a powerstat and is rated for up to 3 amps. I figure that that should be ample for a tube radio or a small TV.
Man! Doing this stuff is GREAT!
