Old 04-02-2005, 02:48 PM
24"? Packard Bell
This Packard Bell Model 2301 looks like it might be a 23" or 24" round metal tube?
http://cgi.ebay.com/ws/eBayISAPI.dll...167771792&rd=1
Eric
Old 04-02-2005, 03:16 PM
Steve K Steve K is offline
Eric:
The 2301 uses a 19AP4 picture tube. He has been trying to sell that set for a long time on eBay. If it wasn't such a long drive for me and if gas wasn't $2.43 a gallon I buy it.
Steve
Old 04-03-2005, 12:33 AM
OK, guess the cabinet is smaller than it looks, the tube looks huge!
I'm in driving distance but don't need a major project like that.
Old 04-03-2005, 10:05 AM
zacster
Guest
Posts: n/a
Hmmm. 19AP4 is the same tube that my DuMont has, and I still don't know whether mine works either. From the looks of this one, I have a better chance with my own tube since my set is in almost perfect shape cosmetically. Unfortunately this one is in So Cal and I'm in NY.
Old 04-04-2005, 07:41 PM
sixt8mopar's Avatar
sixt8mopar sixt8mopar is offline
AK Subscriber
Well now that I am kinda hooked on old TVs......I just picked up a Packard Bell on the weekend.It was missing a couple of tubes,which I just replaced.I did power it up with the dim-bulb.I haven't checked the other tubes but this is what I have got so far for a picture.I have sound,which is pretty clear.It has one of those picture brightners on it as well,almost thought of tearing it off.Any ideas?
Main:Marantz 2220B ,Yamaha CDX-1100U, Thorens TD160 , Klipsch Forte II's
Mancave:Yamaha C-6, M-2, T-1, CDX-1110u, KX-930, PF-800, AR9's
Old 04-04-2005, 07:47 PM
Try adjusting the horizontal hold which might be enough to lock in a picture. It also looks like the vertical linearity is off which usually requires the replacement of capacitors in the vertical sweep section.
Steve
Old 04-04-2005, 08:45 PM
sixt8mopar's Avatar
AK Subscriber
Took quite a while for me to get a picture in.Here it is.....
Old 04-04-2005, 09:21 PM
Hey, doing good! The picture tube does look a little weak but certainly strong enough to use until the day you come across a replacement.
Old 04-08-2005, 06:33 PM
sixt8mopar's Avatar
AK Subscriber
Well after letting this guy run for a couple of hours each day through the week.......the picture has taken over!The small gap at the bottom dissappeared.It is not to bad now.But yes re-capping is probably a good thing.Anyone know what year this PB is?
Old 04-08-2005, 07:07 PM
I believe that your set is a 1953 model but if you can give us a model number I can let you know for sure. It should be something like a model 2043.
Steve
Old 04-08-2005, 08:07 PM
sixt8mopar's Avatar
AK Subscriber
It is model 21401 I believe.
