Old 04-03-2005, 08:04 PM
tubino's Avatar
tubino tubino is offline
A guy with too many tubes
RCA Victor - seeking info
Pictures tell all I know.
deHavilland UltraVerve+Aries 845; L. Moore UltraFi Monaco
Tannoy GRF-R, DMT15; '52 Jensen Imperials+JBL LE15B; JBL 2226+2441+Edgar, Yuichi horns
Old 04-03-2005, 08:05 PM
tubino's Avatar
Label on back
The important model number?
Old 04-03-2005, 08:17 PM
Electronics Accumulator
Well, it looks like you've got a television set there. A sort of receiver for mindless images and sound. That particular one appears to be a black and white model. It also looks heavy.
<grin>
Looks like one of the classic 14" RCA metal portables - I know they made them in many different colors and styles, mostly in the late fifties or so. Here's a similar set - http://www.vintagetvsets.com/redrca.htm
Don't know much about them though. I'm sure someone here has more information. I do know that some of the small metal cased sets had issues with heat, or rather the overabundance thereof.
-Ian
Old 04-03-2005, 08:34 PM
tubino's Avatar
Back view
From the rear...
Old 04-04-2005, 09:32 AM
Bill Cahill's Avatar
Super Moderator
Cool RCA Victor tv
It is a mid, to late 50's portable b w tv. The number you showed is not the model. That might be on a tag on eiither the bottom, or inside. It will need re-capping, and new electrolytics to start off. Also, this set was made when thrther cut surg, as they are more efficient than the seleniums were. If not installed, you will likely blow your electrolytics.
Old 04-04-2005, 09:39 AM
Super Moderator
what happenned?
Call me, or e-mail me. I tried making corrections, and it keeps getting rid of what I am writing. I can tell you then. [email protected] damn, I hate computers!!!!!!!
Old 04-04-2005, 09:43 AM
Super Moderator
Cool RCA Victor tv
It is a mid, to late 50's portable b w tv. The number you showed is not the model. That might be on a tag on eiither the bottom, or inside. It will need re-capping, and new electrolytics to start off. Also, this set was made when seleniums were still being used.You will have to use appropriate silicon replacements with a correct value resistor to further cut surge, as they are more efficient than the seleniums were. If not installed, you will likely blow your electrolytics.
Old 04-04-2005, 10:58 AM
tubino's Avatar
Thanks, Bill! I just want to find a good home for it. It is a complete unknown as to functioning condition. I would love to hand it off at AK Fest. Value/worth? Any ideas?
