Old 04-25-2005, 03:47 PM
mg196's Avatar
mg196 mg196 is offline
Johnny Thunders - LAMF
Sparton tube radio identification please!
My dad found this piece and we were wondering if anyone had any specifics on it:
Old 04-25-2005, 03:49 PM
mg196's Avatar
Here are the guts, followed by some close-ups of some tubes.
Old 04-25-2005, 03:56 PM
mg196's Avatar
Here are pics of a couple tubes.
Old 04-25-2005, 03:58 PM
mg196's Avatar
Last pic:
Old 04-25-2005, 06:13 PM
Tom Bavis's Avatar
Audiophool
8W10 is covered in Sams folder 126, 1951. I'll see if I have it.
Old 04-25-2005, 08:52 PM
Tom Bavis's Avatar
Audiophool
OK, I'm back from the basement, clutching a copy of the Sams folder. Made by Sparks-Withington, Jackson MI. Original will cost you a few first class stamps. A scan will cost you an email. tbavis(at)aol(dot)com
Old 04-28-2005, 07:18 AM
mg196's Avatar
Hey Tom, could you give me an idea of what type of unit it would have been installed in? Console? Stand alone?
Additionally, is there a simple way to test if these tubes are functioning? Are they worth testing or are they standard run-o-the-mill?
Old 04-28-2005, 09:23 AM
Tom Bavis's Avatar
Audiophool
It's a stand-alone - just hook up a FM antenna - but where's the speaker? Output transformer is probably mounted to the speaker... Tubes are pretty common. I would run it up with a variac or a light bulb in series just in case... adding a fuse is a REAL good idea too. Caps are more likely to be bad than the tubes.
