Old 06-12-2005, 09:59 AM
zenith2134's Avatar
Picture Tube Restorer?
Just acquired a Beltron 2972 Picture tube testing/ restoring system. The problem is that at the top where it says red/green/blue gun test, and 'heater voltage' there are empty spaces w/ wires for each empty socket just hanging. Were these sockets or Meters? I saw an older one on ebay with meters in these spots. Where can I obtain meters to work with these voltages?
Old 06-12-2005, 02:52 PM
blue_lateral's Avatar
Theyre meters. Somewhere I think I have a schematic that was meant to "clone" a Beltron. I'll dig a little tonight and see if I can find it. Maybe the meter movement sensitivity is listed.
jc
Old 06-12-2005, 09:13 PM
kc8adu's Avatar
kc8adu kc8adu is offline
iirc the store has half or so of a beltron with the meters.
maybe take 2 and make a good one?
i will ask the owner tomorrow.should be cheap.
email for more info
Old 06-13-2005, 08:01 PM
I had a buddie that hooked up a older beltron to a in line crt. He blew the neck right off when he gave it a bolt on high setting. I never laughed so hard in my life.
He was not happy, It belong to a customer. {Be careful with it}
Old 06-13-2005, 08:29 PM
Yeah, you have control - up to a point. When you let go the button go, it keeps blasting until things cool off. moderation is the key here.
I'm still looking for the schematic.
Old 06-13-2005, 08:42 PM
Big Dave's Avatar
Big Dave Big Dave is offline
Dead from the neck up
I use a Beltron as well. I like the fact that I can adjust the heater voltages and just let the tubes cook. I only rejuvenate as a very last resort.
The world's worst TV restoration site on the entire intranoot and damn proud of it.
http://evilfurnaceman.tripod.com/tvsite
Old 06-15-2005, 12:22 PM
zenith2134's Avatar
Thanks. I didnt use it yet but I'll exercise caution and try it on an otherwise junk set first. The problem though is that I just realized that the voltage control is missing, also, so I have to get one.
Old 06-15-2005, 04:12 PM
El Predicta El Predicta is offline
Beltron
There's no other restorer even close to the Beltron. Good luck on the rebuild.
Old 06-16-2005, 12:13 AM
Fake Beltron Schematics... get 'em while they're hot.
I found the schematic and scanned it. PM me with your email address if you want it. It's a 3MB zip file.
The meters are: (1) 0-100ma DC (2) 0-1ma DC (3) 0-1ma DC (4) 0-1ma DC (5) 0-15v AC.
The voltage control is a little less obvious. These are bad xeroxes of hand drawn schematics, and there are some inconsistencies.The only likely suspect on the parts list is a "25 ohm 1 amp ohmite".
