Admiral AM FM Radio identification
I have an Admiral AM FM tube radio, probably from the 60’s or 70’s that I am trying to identify the model number and/or chassis number, as I need to get a schematic for troubleshooting purposes. The model number was on a tag attached to the bottom of the radio that has detoriated with age and this information is missing. Here is all the information that I have found:
Mfg.: Admiral (Made in Japan for Admiral) Serial Number: 522406 Chicago 47, Illinois Inside the radio case is stamped: T 40.11.1 WATABE Information that is still visible on the tag located on the bottom of the radio: Tubes listed for the radio: 12AV6 - 1 each 12BA6 - 2 each 12BE6 - 1 each 17EW8 - 1 each 50EH5 - 1 each Also, on the tag is stamped N40D440-282 The radio is in a wooden case, has 2 speakers, one on each side with the controls and station dial in the center section. Has 4 Control Knobs: (Off/On/Volume) (Tone) (AM/FM/AFC/Phono) (Tuning) On the back there is a Phono input jack as well as FM antenna terminals. The dimensions of the radio are: 14 inches wide by 5.5 inches deep by 8 inches tall. This is all the information that I have found or identified; any help in identifying the model number and/or chassis number of this radio is greatly appreciated. |
