Old 08-13-2005, 08:56 PM
Nolan Woodbury's Avatar
Nolan Woodbury Nolan Woodbury is offline
Shaken, not stirred
Schematics needed
Hi everyone,
Over the next few weeks I plan on replacing the paper and electrolytic capacitors on all my 'user' radios, but need to order the proper values. Does anyone have the schematics for the following?
1) Zenith G/C730 (chassis # C705)
2) Zenith K731 (chassis # 7M07)
3) Zenith H845 (chassis # 8H20)
I realize I can order these from justradios.com, but if anyone has them handy, that would be great. Are schematics usually sent in a pdf format?
Finally, any collective wisdom for recapping the H845? I've read these need less updating than other, older sets. Suggestions? Where's a good place to put an in-line surge fuse?
Old 08-13-2005, 09:58 PM
Chad Hauris's Avatar
I may be able to scan you the sams tomorrow. It will be a jpg file hosted on our site so you can download it, then I'll remove them once youve got them to conserve our disk space.
I always put the fuse right first where the power enters the set in the hot lead. That way if anything shorts. filaments, diode, whatever, it blows.
1/2 amp would probably do for a table top radio.
If a set is using ceramic capacitors they are usually still good. You may be able to upgrade your audio quality by replacing any ceramics in the audio circuit with mylar. I'd go ahead and just do those electrolytics while you have the chassis on the bench, even if the old one looks good, just so you don't have hum problems creep up in the next 5-10 yrs.
Chad Hauris
Old 08-14-2005, 01:30 AM
Shaken, not stirred
Hi Chad,
That'll be great. I'll try to download and save right away.
I think this is an important upgrade, because plugging and unplugging a set seems a major hassle. That's the main concern, correct?
I'm almost positive the H845 uses ceramics. I wonder how many are in the audio circuit? Perhaps just one?
If you can't get to it right away Chad, don't worry about it. Feel free to send me a PM or a email after you upload.
Thanks again Chad, as always!
Old 08-15-2005, 05:29 PM
Nolan, I couldn't find the sams index last night and was time to go home. I know I can find you those sams but I need to find that index. If you can find out what folders those radios are in it will help.
Chad Hauris
Old 08-15-2005, 09:20 PM
Tom Bavis's Avatar
Audiophool
H845: 725-10
K731: 778-10
C730: 478-19 - I might have this one... none of the others though...
Old 08-17-2005, 08:14 AM
Tom Bavis's Avatar
Audiophool
Nope - don't have 478...
Old 08-17-2005, 08:24 AM
Tom thanks for finding those numbers, I should be able to find those sams this weekend.
Chad Hauris
Old 08-29-2005, 12:05 PM
Nolan I haven't forgotten about those sams but have had a lot of juke work at the shop so haven't gotten to them yet but I should in this week sometime.
Chad Hauris
Old 08-29-2005, 12:39 PM
Tom Bavis's Avatar
Audiophool
If you do scan the Sams for the G730, I'd appreciate a copy - I picked one up this last weekend at the AWA flea market. It will join my C730, T825, 8H061, L600, R615 and maybe a few others that have slipped my memory...
Old 08-29-2005, 04:59 PM
Shaken, not stirred
No problem Chad. I just returned from a 10-day business trip, so I haven't had any time either. Thanks for the shout-out!
Old 09-03-2005, 09:11 PM
O.K. the sams are ready:
http://www.retroaudiolab.com/sams
Chad Hauris
Old 09-04-2005, 11:46 AM
Tom Bavis's Avatar
Audiophool
Got it - thanks!
Old 09-07-2005, 01:59 AM
Shaken, not stirred
Me too...thanks Chad and Tom. Much appreciated!
