Old 09-06-2005, 04:38 PM
James Carroll
Guest
Posts: n/a
Info Needed - Regency TM-H2 Monitor
I have a Regency Monitor Radio (cir. 1973) Model TM-H2. This monitor takes the solder in crystals rather than the newer style plug in crystals. I would like to locate a source or manufacture to supply the following frequencies: 155.505, 159.225 & 151.430. I'm not sure of the I.F. for this model. The newer monitors with plug-in crystals use 10.7 ( HIGH BAND = LISTENING FREQUENCY - RADIO I.F. (10.7) Then Divide by 3. Can anyone tell me the correct I.F for this model and a source or manufacture of solder in crystals? thanks. ([email protected]
Jim
Old 09-06-2005, 04:55 PM
mhardy6647's Avatar
mhardy6647 mhardy6647 is offline
Did you try Universal Radio?
http://www.universal-radio.com/
all the best,
mrh
Old 09-06-2005, 06:28 PM
James Carroll
Guest
Posts: n/a
Regency TM-2H
MRH
Thanks for the lead
Jim
Old 09-07-2005, 07:29 AM
Tom Bavis's Avatar
Audiophool
The schematic can be found in Sams Photofacts number 1294-SED. The SED numbers are schematic only, not the usual complete service information...
Your local library may be able to get you a copy.
