Old 10-07-2005, 10:25 AM
andrefranc andrefranc is offline
VK Member
Vertical Hold won't roll the pix down
Where is the problem, in what circuit, the Vert. osc or Vert. output, when the vertical hold works but won't roll the picture down? this is on an older B&W RCA KCS38.
Thanks, John
Old 10-07-2005, 10:43 AM
Chad Hauris's Avatar
The vertical oscillator frequency is probably not right...have you replaced any old capacitors? Does it have a steady picture? If the control will only move it in one direction the oscillator is too far off the center 60 hz frequency.
Chad Hauris
Old 10-07-2005, 10:48 AM
Randy Bassham's Avatar
If your picture has good height and linearty I'd suspect a problem in the oscillator
circuit.
KAØSCR
