Old 10-14-2005, 11:52 PM
polaraman's Avatar
<--1956 300B
TRK 12 on Ebay
What a beauty she is!
polaraman
http://cgi.ebay.com/RARE-ANTIQUE-RCA...QQcmdZViewItem
Old 10-15-2005, 01:08 AM
John Folsom's Avatar
Amyone know who the seller is?
John Folsom
Old 10-15-2005, 01:52 AM
If I recall correctly, TV scan rates were different before the war. 441i/30 instead of today's NTSC 525i/30. Which means that he modified this set's scan circuits to accept NTSC rates so it could deal with "I love Lucy" videotapes. Not unreasonable, as most people would expect to see a viewable image on a "working" antique TV set. Not accurate, though.
Old 10-15-2005, 02:01 AM
Old 10-15-2005, 02:13 AM
It could have been modified in the 40's after the NTSC standard was put in place.
Old 10-15-2005, 06:35 AM
David Roper's Avatar
console lover
No mods necessary for it to work, though some very slight mods might make it work a little better such as alignment of the sound IF for best results with the AM detector for slope detection of the FM audio; also there's a few minor changes that can be made to the horizontal sweep section if the width is insufficient, however the range of the horizontal hold control should be ample enough to allow the set sync to NTSC.
tvontheporch.com
Old 10-15-2005, 11:57 PM
Jonathan Jonathan is offline
Damn, is that ever a beauty... I hope it gets a good home.
Jonathan
Old 10-16-2005, 11:37 AM
mkerdman
Guest
Posts: n/a
Radio pushbuttons, original or reproductions, available for the TRK-12?
Are there any radio pushbuttons, original or reproductions, available for the TRK-12?
Murray
[email protected]
Old 10-18-2005, 08:08 AM
fredh's Avatar
fredh fredh is offline
Can you believe it? $3000 and the reserve has been met. The 12AP4 would nearly go for that much. If I didn't already have one I'd be bidding. It's a beauty.
