Old 10-24-2005, 03:27 PM
Telecolor 3007's Avatar
I love old stuff
Lightbulb Do ya still use your old tv's?
Do you still use your old tv sets? (I use from time to time my 1984 Telecolor as tge 2nd set in da house).
Sailor Moon
Old 10-24-2005, 03:39 PM
jpdylon's Avatar
jpdylon jpdylon is offline
<-- sucker for old sets.
All I have in the house is old tv sets. My bedroom tv is a 1968 Zenith color set that is still working ok, although it will need some service soon as the vertical is becomming jittery. My listening room has a 1974 Zenith Chromacolor II that hardly has any hours on it. It needs a new trippler, but afterwards it will be fine. The living room has a an RCA colortrak 2000 from 1983 that is still working fine except for the worn out touchpad. it has a remote the size of a small book. Other sets I have are in the works, but once I'm done repairing them, I'll put them to good use as well.
Jordan
Old 10-24-2005, 04:55 PM
frenchy frenchy is offline
Frenchy
Once in a while, especially if an old 50s or 60s color show happens to be on free tv (don't have cable). A portacolor in the bedroom occasionally and a cherry ctc-16 in my living room, till I get the ctc-10 with the remote control finished up and in it's place. Oh yeah and a little Zenith porthole in the living room in a corner I watch I love Lucy on from time to time.
Old 10-24-2005, 06:17 PM
Carmine's Avatar
Carmine Carmine is offline
...enjoys spaghetti.
This B&W Zenith from '58 (I think) sees almost daily use for an hour or so each night. It's never been recapped. It has a microphonic vertical tube... every half hour or so a light smack solved the problem. Hasn't bothered me enough yet to open it up.
The newest set in my house is a 27" Zenith from 1990.
From Captain Video, 1/4/2007
Old 10-24-2005, 06:31 PM
Big Dave's Avatar
Big Dave Big Dave is offline
Dead from the neck up
I play my restored sets about two hours per week. My big Zenith combo serves as the main watcher.
The world's worst TV restoration site on the entire intranoot and damn proud of it.
http://evilfurnaceman.tripod.com/tvsite
Old 10-24-2005, 07:16 PM
Adam's Avatar
Adam Adam is offline
I also only have old sets. My newest is a portacolor. I hardly ever watch that. I used to watch my 67 zenith color all the time, but now I think the filter caps in the power supply are going bad giving the picture that 'wavyness'. Lately I have been watching alot of my 59 maganvox B&W console (the one with the newer replacement crt), and my 61 zenith 23" B&W.
Old 10-25-2005, 08:15 AM
holmesuser01's Avatar
My RCA CTC-10C gets run about two hours a week. I've noticed that some of the vertical issues (retrace) is going away on its own. The only problem that it still has is 60 cycle hum in the audio. I also have a Zenith 21" B/W set from 1958 complete with the remote control. It runs decently, considering it sat in a closet for 30 years.
Old 10-25-2005, 10:41 AM
Old 10-25-2005, 12:53 PM
I don't won't much tv on my own (mostly its me reading the paper while my wife is watching). If something worthwhile is on I'll fire up an old set. I try to rotate. Lately it has been my porthole, because its the last one I fixed. Prior to that it was the CTC-11; Zenith 25MC30; Motorola 21" color; CTC-12; CTC-5 (in descending order)
Old 10-25-2005, 03:19 PM
My Zenith Sentry 2 (1995) in my bedroom doesn't get much use except as a backup to the RCA CTC185 (1999 vintage) in the living room. I do fire up the Zenith every now and again just to see if it still works, which it did the last time I checked. The set has a beautiful picture on its original CRT--I'll probably move it to the living room if and when anything happens to the RCA, since the latter is out of warranty and may not be worth repairing again--it depends on what goes wrong with it next. (If the CRT goes, I'll junk the set without thinking twice.) I say "if and when" because the RCA still makes a wonderful picture on cable, my VCR and DVD player, and still has its original CRT. The set has almost six years on it now; the way it's going, I may still be watching it in 2009 when all TV is set to go digital. I've only had one problem with the RCA in all the (nearly) six years I've had it: the RF port on the tuner PCB snapped off the board shortly after I bought the set, and I think the jungle IC has something amiss as the tech who fixed the RF port problem (the set went to a repair shop in the next town south of here for the repair) informed me that his lab tests showed some minor problem with the chip. However, the TV still works well on cable as I mentioned, so I guess the jungle IC can't be too badly damaged.
Old 10-25-2005, 08:58 PM
JCFitz JCFitz is offline
I don't have anything real old but I use my little 1982 GE 10" tv every day while I'm on the computer and the news is on and sometimes all evening if I'm watching local programming as I don't have an outdoor antenna,DirectTv won't let me have CBS or ABC thanks to my local stations and it picks up much better than my 1985 Zenith Advanced System 3 which i use for watching DirectTv,DVDs and videos.Both sets are running strong with good color.The last one to need repair was the Zenith.2 problems.One was heat fatigued solder connections and the other was caused by a mouse that got into the set and peed on the circuit board.The strange one was the GE when I got it originally would play for a while and then the vertical would collapse.I thought it needed griplet repair which that chassis usually needs.I played it a few evenings while working on other things and one evening it didn't act up.Has been playing without a hitch for over 2 years.Never seen a tv fix itself.My uncle used a 1968 Zenith combo every day til 2000 when he got a refurbished Toshiba projection tv.He's still got a 1979 Zenith Chromacolor 23" with one knob tuning in his den.Gets used a lot.And an early 70's Panasonic in his bedroom.
Old 10-25-2005, 09:28 PM
tv beta guy
Guest
Posts: n/a
Well, my daily watcher TV is a 1996 GE/Thomson set. After doing the tuner board repair and such, it has worked perfectly for the past 9 soon to be 10 years with a lot of use.
But for old TVs, I regularly use the solid state TVs I have, which range from 1972-1985. The all tube and hybrid sets I use only on the weekends, which are from 1965-1976 (Oldest one I have is from 1960, but needs restored.)
I actually got a mint '68 Portacolor earlier this year. I turn it on once a month for an hour maybe 2 at the most. I actually set the sleep timer on it to shut it down after that time. I want to be able to use it, but keep the hours low on it.
There's just something magical about watching a 30-50 year old TV that you won't get with a modern black/silver plastic box...
Am I the only one that likes that distinct smell of hot vacuum tubes?
Old 10-25-2005, 09:47 PM
...or watching the little white dot slowly fade away when you turned it off...?-Sandy G.
Old 10-25-2005, 09:53 PM
tv beta guy
Guest
Posts: n/a
Oh yeah I even had one that did it in reverse... it did it as it warmed up
Old 10-25-2005, 10:20 PM
Frenchy
It works best and lasts longer if you turn the brightness way down before you turn it off, hee hee!
That's even fun to do on a Portacolor, ever try it, especially after you crank down the brightness? It does the dot thing but it splits into the 3 separate color beams and they are real bright dots and kinda twinkle as they go out, pretty cool.
