Old 01-16-2006, 02:22 AM
Charlie's Avatar
Charlie Charlie is offline
On Land
Polaraman, here's your CM's B&W cousin!
Wow... I never thought I'd see another one of these Curtis Mathes sets with the top hutch! If you guys recall, Polaraman got one last year with a color set. Here's one with a B&W set.
http://cgi.ebay.com/Curtis-Mathes-Co...QQcmdZViewItem
Charlie Trahan
Old 01-16-2006, 02:34 AM
The picture tube is well ventilated on that set!
Old 01-16-2006, 02:38 AM
Charlie's Avatar
On Land
Ahhhh... i see. I thought that was a glare on the glass from the camera. Instead, it's a glare from the big hole in the back!
Charlie Trahan
Old 01-16-2006, 02:58 AM
blue_lateral's Avatar
Yeah, slightly gassy..... I wonder if thats an easily obtainable tube?
Old 01-16-2006, 08:23 AM
polaraman's Avatar
<--1956 300B
I saw that set on Ebay. I did not post it because most of us do not like large console sets. If it were closer I would bid on it. Mine has great sound. I use the record player and radio more than the TV.
The movers had a really difficult time getting that set out of the house. I pulled the CRT to keep them from busting it. They struggled but they got it. I can't wait for the movers to deliver it here. hahahahah!
polaraman
Old 01-16-2006, 08:56 PM
Chad Hauris's Avatar
I have one of these b/w sets with top hutch, mine is the French Provincial style.
http://www.retroaudiolab.com/pictures/cm1small.JPG
I got in into a room in my house by turning it on its end and scooting it along the rug. It was too long to turn in the hallway sitting on its bottom. The CM black and white sets are very good quality chassis, using a 90 degree large neck CRT. I still need to replace some caps to really get it to work better.
Chad Hauris
Old 06-12-2008, 08:25 AM
sealforvr sealforvr is offline
Did you guys get that beast fully restored yet? i'd love to hear how it turned out!
Curious minds and all that!
Thanks
Brock
Old 06-17-2008, 01:50 AM
No I haven't gotten around to doing any more with it yet! I think I probably have a lifetime's worth of TV repair projects but I will get to it eventually.
Chad Hauris
Old 06-22-2008, 10:29 AM
Reason I ask is I have a handle on m CM b&w console in Lancaster TX. Seller says everything works, just needs a new needle for the changer, and would like to know what to look out for.
Thanks
Brock
Old 06-29-2008, 02:06 PM
eBay listing for CM TV is invalid
The eBay listing for the Curtis-Mathes TV being discussed in this thread has been removed. I tried clicking on its link just now and got back an "invalid item" response. Those of you who have already seen the listing must have gotten to it long before it was canceled.
BTW, the pic of Chad's B&W CM console could be close to the one we're talking about here. The only differences: one, the cabinet is finished differently, and two, Chad's set works.
BTW (2): What actually happened to that CM console with the "well-ventilated" CRT? Did someone knock the neck off? If there is a large black or clear spot at the center of the screen, and it is possible to see through the front of the tube to the back of the set, these are dead giveaways that the neck has been hacked or knocked off the tube. Whomever did that is darn lucky the tube didn't implode and send glass flying everywhere. The "clear" spot I mentioned would be created when the sudden inrush of air following the breakage of the neck would literally blow the phosphors off the screen at the center.
Finally, I wonder what the opening bid was for that set. I'm guessing it was fairly low, considering the broken CRT and whatever other problems, if any, the TV may have had. Personally, I wouldn't pay more than perhaps $50 at most for a television set with a broken CRT. Depending on how rare the tube is, it could cost at least that much for a replacement.
Oh well. Someone probably won that set by now and could be using the TV chassis for parts, retaining the stereo/phono/radio components and rewiring them to operate without the television, or they could have taken out the old TV chassis and put in a modern color set. I had relatives who owned a very large RCA console b&w TV and did just that when the television quit--they simply pulled out the defective b&w chassis and replaced it with a new Zenith table model that would fit the opening vacated by the old set, using a wood frame to take up any unused space around the set as the new one was somewhat smaller than the original chassis. I also had a great-uncle who, after his 1962 RCA three-way console TV/radio/phono gave up in the '70s, did the same thing, only he used an Emerson table TV to replace the old worn-out RCA. I'm sure many other people have done this in the past with console sets which had very finely crafted cabinets; I'll say this much--that sort of conversion beats heck out of gutting the cabinet, putting the chassis unceremoniously on the tree lawn to die a certain death in a landfill (! ! !) and using the cabinet as--heaven forbid--a fish tank.
