Old 02-22-2006, 04:01 PM
ghola
Guest
Posts: n/a
console radios as guitar amps
I just purchased 3 old console radios: Philco 51-1733, Motorola 7F-11, and Bradford SL-480(8?). Want to try to use phono connection for a guitar, turning console into small practice amp. Anyone ever do this? Im not a tech, but can follow directions. Obviously, I still have to determine whether these things even work! I havent plugged them in yet, and I hope no one already did.
Old 02-22-2006, 06:42 PM
Chad Hauris's Avatar
If you don't have technical experience I would not recommend it (without further learning), tube type equipment can be dangerous...
Also there is not enough gain in the radio's audio amp stages "as is" to amplify a guitar, you would need to design a pre-amp stage.
Chad Hauris
Old 02-22-2006, 10:22 PM
As a radio guy and sometime guitar player, I can testify that a small practice amp will sound fine and work much more reliably. I'm still using the little Roland practice amp that I bought about 15 years ago. Try this:
http://search.ebay.com/guitar-practi...fsooZ1QQfsopZ1
Or,
http://www.tradingmusician.com/
if you live near Seattle and are looking for something vintage.
Old 02-23-2006, 01:29 AM
crooner's Avatar
crooner crooner is offline
Tube Marantzed
Phil: nice to see you in AK. I've followed your radio restorations with great interest over the years. I am sure fellow AK members will greatly benefit from your knowledge!
Marantz 7, 8B & 10B
Old 02-23-2006, 05:24 PM
ghola
Guest
Posts: n/a
Point taken. Wouldnt the phono (turntable) utilize a pre amp? Or would it still not be enuf? What about a line livel (no speaker) output connection? Also, should I invest in a variac b4 turning these on, or would I try tube tester first? Thanks.
Old 02-23-2006, 10:45 PM
Usually console radios which have phono inputs or phonographs use a ceramic or crystal cartridge which has a higher output than a guitar...magnetic phono cartridges do use a preamp and have an output level like a guitar or microphone, however these are usually not used in older consoles.
A better unit to use as a guitar amp substitute would be a PA amp...the pre-amp stage is already there.
Chad Hauris
