Old 03-02-2006, 08:46 PM
Ernie
Guest
Posts: n/a
Question Hoffman TV - Improper Picture Height
Hi all. I recently bought a vintage Hoffman television from a house sale and it works great except for improper height of picture, which my Sylvania TV Repair Booklet says could be caused by improper voltages supplied by low power supply, resistors changing their values, or bad vert osc tube. I tried adjusting vert hold and vert linearity and the picture is maxxed at about 50-per-cent of the screen height, centered in the screen.
I am wondering if anyone else has had this problem and if it might just be a bad tube or other part?
Also, I have heard of people changing all the electrolytic condensers in old equipment as one of the first things they do. Is that really necessary or could I let it go? I really don't want to be installing new stuff in this set (yes I am aware of drilling out old condenser cases and hiding new ones inside).
Thanks in advance for any help!
Old 03-02-2006, 09:21 PM
Big Dave's Avatar
Big Dave Big Dave is offline
Dead from the neck up
Replace all electrolytic and paper caps. If your set uses black plastic caps, get rid of them too. if one of the lytics fails, it could do irreversable damage. Chances are, most of the tubes are good. Recap the set. The caps are the culprits.
The world's worst TV restoration site on the entire intranoot and damn proud of it.
http://evilfurnaceman.tripod.com/tvsite
Old 03-02-2006, 09:37 PM
Ernie
Guest
Posts: n/a
Hey Dave
I'll try that over the weekend and see how that works out. Hopefuly that may clear up or at least partially fix the problem. I could see if some of the condensers have high leakage or are shorted it could be messing up the voltages. I guess I'd be looking in the wrong places if I just started popping tubes.
On a side note, I have heard of tubes lasting for decades while the condensers go bad. Yet I have a big box full of electrolytic condensers from the 50's-60's, which I have been collecting over the years. Most of the values are dead-on when I test them with my meter and have been using them in small projects with no problems. Did I just get lucky with these? Or maybe they just haven't failed yet?
Old 03-02-2006, 09:42 PM
Big Dave's Avatar
They haven't failed yet. They will fail. You can hide the replacements under the chassis and leave the cans in place.
Old 03-02-2006, 10:01 PM
Ernie
Guest
Posts: n/a
Hey again. I'm actually working on uit now. I have the chassis out and am cleaning the dust out of it and the cabinet right now. Should the ceramic condensers be replaced, too? I remember reading somewhere that although they are more reliable then electrolytic ones it's not by much.
I'm thinking I should also lift and test resistors while I'm at it. The thing is heavy enough that I may as well do as much as I can in one shot.
Oh by the way, the chassis is such that you can't see underneath it from the top, and in order to get underneath, everything - including the CRT - has to come out as one unit. o I guess I'm not so worried about authenticity anymore. (-: Of course, I'll leave the two large multi-sectional filter condensers and hide new ones directly underneath.
Old 03-02-2006, 10:06 PM
Ernie
Guest
Posts: n/a
Here are some pics!
What a mess!!!
Old 03-02-2006, 10:40 PM
peverett peverett is offline
I see that this set has the dreaded "disintegrating plastic" yoke. I have 1 Hoffman and several RCAs and Zeniths with the same problem. I do not know what kind of plastic was used, but I wish that they had chosen something else.
Old 03-02-2006, 11:12 PM
Ernie
Guest
Posts: n/a
Ah that must be why it rotates freely on the neck. No worries. On a positive note, it can actually make it easier to adjust, and when I am satisfied I'll just put a dab of hot glue, which I can always peel off if I need to readjust.
Old 03-02-2006, 11:14 PM
Adam's Avatar
Adam Adam is offline
"Replace all electrolytic and paper caps." -- I second that, even if some of them are good now, they will just go bad later if you watch it for a while. The ceramic caps rarely ever go bad, I wouldn't worry too much about them.
What is that gear and chain on the back of the tuner? Does this set have power-tuning or a remote?
Old 03-02-2006, 11:30 PM
Ernie
Guest
Posts: n/a
I'm not sure exactly what that is for. The front knob says "Fine Tuning" but they both seem to turn in unicen.
This is a VHF-only set by the way. It is interesting to note that the back panel has a layout for the UHF if it were present, and the chassis seems to suggest a possible installment of a UHF tuner on some models.
Old 03-02-2006, 11:32 PM
Ernie
Guest
Posts: n/a
No remote. Just a dial.
Oh I just remembered. There is a position for UHF on the dial. It is just a dot, no number. I wonder if I could hook up an external UHF tuner to this somehow?
Ah well. Let's fix the display problem first. (-:
Old 03-03-2006, 11:11 AM
Yes, and aftermarket "set-top" UHF tuner is easy to add and they are plentiful. Or you could just feed it from an old vcr.
Vertical problems like this are extremely common-one of the most common problems in my experience. Usually its due to bad paper caps. If that doesn't cure it look for a bad resistor somewhere in the circuit.
This looks like a reasonably well built tv. It should be a good performer when it's all wrapped up. Glad you joined us-keep us posted!
Old 03-03-2006, 02:49 PM
yagosaga's Avatar
yagosaga yagosaga is offline
VK Member
This is not really a good recommendation. It s better to check the circuits and to find the failure. So you have the opportunity to learn something.
If the capacitors made of wax and paper, there is no need to replace them. You can take them out of the chassis and "cook" them in 110°-degrees-Celsius hot wax. The water will boil and evaporate. After that the old capacitors are like a new one. Perhaps they have lost 5% - 10% of capacity, but this is within tolerance.
Old 03-03-2006, 03:06 PM
Exclamation
Originally Posted by yagosaga
If the capacitors made of wax and paper, there is no need to replace them. You can take them out of the chassis and "cook" them in 110°-degrees-Celsius hot wax. The water will boil and evaporate. .
I don't know about that. The paper may have acid in it, and may have reacted with the moisture to degrade the foil and the paper. MY father had mentioned this cooking method, but that was 35 years ago. Might have worked back then, but I wouldn't trust it today.
Old 03-03-2006, 03:39 PM
Adam's Avatar
This is a good idea. It is not best to just go randomly replacing stuff. I do try to check the circuits to find specifically what is wrong when I'm fixing a TV, the information might be useful if something else goes bad later on.
But after I fix the problem, then I still go and change all the wax and paper caps even if they are good at the time. I'm hardly an authority on the subject, but I've just found on sets where I haven't replaced all these they tend to go bad after having watched the set for a while, and I just keep having to take it apart to change them later. I've never tried that method of restoring the originals though.
