Old 04-05-2006, 05:46 PM
rca2000's Avatar
rca2000 rca2000 is offline
Could this be a TRK or other RCA projo supply??
I saw this on Ebay, and it LOOKS like a PS chassis, from an rca TV, perhaps a TRK or maybe a projo from '48-49. Maybe not. Perhaps someone else knows!!
http://cgi.ebay.com/Vintage-RCA-5U4-...QQcmdZViewItem
Old 04-05-2006, 05:57 PM
ChuckA's Avatar
ChuckA ChuckA is offline
I believe this is the LV power supply from one of the RCA projection sets, 9PC41, 648PTK and the like.
Chuck
www.myvintagetv.com
Old 04-05-2006, 06:21 PM
Einar72's Avatar
Einar72 Einar72 is offline
Chasin roundies since '79
You are correct, Sir...
I had Mr Poster ship me the 3-chassis set I won on eBay in '04, hope I didn't out-bid anyone I've met here...now if I could find another optical barrel assembly, mine's toast
(rodentus urinarius corrosivum).
Old 04-05-2006, 06:31 PM
John Folsom's Avatar
Chuck is (as uaual) correct. And the same seller also has the RCA audio amp. chassis that was used i n the projection sets (ans elsewhere?).
John Folsom
Old 04-05-2006, 06:52 PM
Einar72's Avatar
The 648PV had the tuner-phono assembly that was also sold as a stand-alone HI-FI console, again using a different-sufixed version of the amp chassis mentioned in this thread.
http://www.tvhistory.tv/1947-RCA-648PV-OPEN-CLOSED.JPG
P.S. I contacted the seller, sadly, he does not have any other pieces to this TV.
Old 04-05-2006, 11:51 PM
kx250rider's Avatar
REAL TVs have TUBES!
I know where there's a 648-PV that probably could be had for little or nothing. It has all of the chassis and barrel, but is missing the BIG radio & phono chassis. Some boob put creosote all over the cabinet, and it STINKS. That's why the owner doesn't want it.
Charles
Old 04-06-2006, 12:33 AM
Einar72's Avatar
Hi Charles
Two silly questions.
Is it still really gooey?
Is it along the I-5 corridor?
Einar
Old 04-06-2006, 12:23 PM
kx250rider's Avatar
I wouldn't say it's still gooey, just smelly if in a closed room. And I don't know how you'd get that stuff off the wood... (I-5 corridor); Basically yes; it's in Encino near the 405 & 101 Freeways. If you are interested, send me an eMail and I will give you the owner's number...
[email protected]
Charles
Old 04-07-2006, 03:30 PM
pallophotophone pallophotophone is offline
CREOSOTE ? Are you sure ?
Why On Earth ? I know it's used on power line poles to preserve them , but a cabinet
which hopefully doesn't spend more than 20 minutes of its' life outdoors ?
ODD!
Bob Hodge
