Old 04-30-2006, 10:41 PM
Charlie's Avatar
Charlie Charlie is offline
On Land
Question Anyone know what causes this?
On many of my b&w sets, there is a verticle line on the left side of the screen. Usually, I only see it between scenes. It's not really noticeable if there's a picture on the screen.
The screen shot below is on my Philco Diamond D set. I also see the same line on my b&w '63 Curtis Mathes, '72 Zenith, '58 Magnavox, and '59 Predicta. Doesn't seem to matter what source I'm using... cable, DVD, air... it's still there.
I've never noticed this on my color sets... just the b&w ones.
This doesn't really bother me... like I said... it's really only noticeable between scenes. Since I have a handfull of sets doing this, I thought maybe someone else might have experienced this as well... and found its remedy???
Note: Don't pay attention to the horz line at the bottom and other wavy lines... those are cause by the digital camera.
Charlie Trahan
Old 05-01-2006, 12:30 AM
kx250rider's Avatar
REAL TVs have TUBES!
Open ground in your CATV system... Very very common. You are probably seeing the signal from your cable box/VCR/DVD, plus a weak piggyback of a local TV station. This causes your exact symptom when you say it's the same on more than one TV.
Is your Cable Box, VCR or DVD set to output on a channel that is a receivable TV channel? BINGO That will cause your line. If both Ch 3 & 4 are channels with local signal being broacast, only relief would be to convert the 300 ohm flat wire that is inside each TV between the ant terminals and the tuner, over to shielded cable. Or you could try wrapping the wire with foil and grounding it, but that might also cause other ghost problems.
Charles
Old 05-01-2006, 12:49 AM
Charlie's Avatar
On Land
Good thought, but line shows up regardless of source. The set in the pic above is running on rabbit ears... not cable. It creates the line with any source... cable, DVD, rabbit ears.
On the other hand, I did as you mentioned (turning to an unused channel) and there is no line.
I've noticed that my '59 Motorola b&w set DOES NOT show this line. So, I would think the problem would be within the sets that do show the line.
Charlie Trahan
Old 05-01-2006, 12:56 AM
Charlie's Avatar
On Land
Strange thing is... I usually only notice this on vintage b&w sets... not vintage color sets.
Charlie Trahan
Old 05-01-2006, 04:03 AM
TV Engineer TV Engineer is offline
Try adjusting the horizontal drive and see if it has any affect.
Old 05-01-2006, 07:05 AM
compucat's Avatar
compucat compucat is offline
1949 Motorola 9VT1
I notice it too on my vintage black and white sets. Fine tuning helps minimize it but it can still be seen sometimes. It is not a signal source problem as I don't have cable in my house, just rabbit ears on all sets.
I suspect it is coming from the horizontal curcuit, some kind of ringing maybe? I think it is just a design characteristic of b&w sets since the horizontal sections don't need to be as sophisticated as in a color set.
It's like an allergy. You just have to learn to live with it.
Old 05-01-2006, 07:13 AM
I think it is the color information. In the old days the station would turn that off when showing a b&w show. But now they leave it on all the time.
Ed
Old 05-01-2006, 07:39 AM
Electronics Accumulator
Ghosts.
Old 05-01-2006, 10:12 AM
Ex-Philco
Remove a video IF tube and see if it is still there. If so, it is coming from the horizontal circuit. It should not be there in the Philco Diamond D. It could be the result of a mismatched yoke and/or flyback if either has been replaced. Make sure they are original parts.
Then check the horizontal oscillator and coupling circuit.
Don
Old 05-01-2006, 12:33 PM
Charlie's Avatar
On Land
Thanks for the ideas, guys. I'll try them in a few days on the Philco when I get back to my cabin (where the Philco is). Later today, I'll be poking around in my 15 and check the stuff that was mentioned last week for that set.
Thanks again!
Charlie Trahan
Old 05-01-2006, 05:34 PM
nasadowsk's Avatar
Damn does run fast…
Looks like a good ole drive line. Turn down the h drive and it should go away.
Old 05-01-2006, 09:35 PM
Einar72's Avatar
Einar72 Einar72 is offline
Chasin roundies since '79
Looks like Barkhausen interference (aka snippets) to me. My 1970's tech-school copy of Grob's Basic Television, covered the subject adequately (but not in the 1949 edition, though). In a nutshell, these undesired oscillations from the horizontal output tube show up as vertical lines down the left side of the raster. They are usually black. Keeping unshielded antenna lines away from the horizontal output section also helps.
Old 05-02-2006, 06:32 AM
Yeah, it does kinda look like Barkhausen interference, but I've never seen it look like that before. That looks more like a video signal interference than the Barkhausen interference, especially since you can only see it in light scenes or whatnot - Barkhausen interference tends to be always there, and like Einar72 said, it's typically black. Another cure for Barkhausen interference is to just swap horizontal output tubes around until you find one that doesn't oscillate.
But I'm still betting on ghosts. The dead have a way of interfereing with television reception. <grin>
-Ian
Old 05-02-2006, 01:28 PM
Arrow
To me it looks like the horizontal deflection slowing down a little midscreen. That would cause more electrons from the beam current to accumulate per given area of the screen, and thus that area will look brighter. Supposidly adjusting the "horizontal drive" trimmer should reduce this, but I have an RCA set where I can't get rid of it. Go too far and I lose horiz sync.
Old 05-03-2006, 03:36 AM
I think the correct term is snivets, not snippets. They are usually black lines or splotches on the left side of the screen and are particularly bad on UHF channels. This problem looks like a drive problem to me.
