Old 06-24-2006, 12:40 PM
funken's Avatar
funken funken is offline
Atwater 55 question
I picked up my Atwater model 55. Just a couple of questions.
There are 3 knoms on the front of the set. One controls the volume, one is the dial selector. What is the third knob?
What is the best antenna for this set. Currently there's an insulated wire serving as the antenna.
I'm very pleased with my purchase. The cabinet is in great shape and the set works. I KNOW I SHOULD'NT have tried turning the set on but the owners beat me to it.
Have a great weekend!
Funken
Old 06-24-2006, 02:37 PM
sean's Avatar
sean sean is offline
Hi Funken,
The AK 55 is a great receiver. I had the table top "coffin" version of that set. The third knob is a local/distant switch. It is used in the distant position to give more amplification so you can receive stations at a distance. In the local position the amplification is not as great so that local stations don't come booming in. That set was made to use a length of wire for an antenna. Usually a 10 foot piece will be sufficient but the longer the better.
I downloaded the instruction manual for this set at one time but I don't remember where I got it. I have uploaded it here: Atwater Kent 55 Instructions
Sean - WØKPX
Old 06-24-2006, 04:19 PM
funken's Avatar
Thanks Sean!!
Great information!!! Time to hook-up the antenna.
Cheers!
Funken
Old 06-24-2006, 04:52 PM
I think you'll get a kick tonite using a longer antenna, turning the knob to "distant" & seeing what she'll REALLY do....Prolly will be pleasantly surprised !!
Old 06-24-2006, 07:05 PM
funken's Avatar
Well I hooked this puppy to my antenna. Great reception. Listenig to Cardinals baseball on my 1927 set.
Does'nt get much better than that.
Funken
Old 06-25-2006, 09:41 AM
sean's Avatar
Where are you located Funken? Were you getting Cardinal baseball at 550? If your not in the STL area I'm suprised you can get it. I'm about 60 miles SW of STL and can't get KTRS worth a darn!
Sean - WØKPX
Old 06-25-2006, 11:14 AM
funken's Avatar
Hey Sean!
I'm in St. Louis.
Mark aka Funken
Old 06-25-2006, 11:16 AM
funken's Avatar
Mar-A-Way
Any of you guys ever use this product on your cabinets?
I saw this product on Radiola Guts website.
Funken
