Old 09-05-2006, 10:30 PM
What's this RCA yoke go to?
Old 09-05-2006, 10:50 PM
Looks kinda like a CT-100 yoke?
http://home.att.net/~pldexnis/potpou...rivia_ans.html
Old 09-06-2006, 01:05 AM
kx250rider's Avatar
REAL TVs have TUBES!
That may be for a CT-100, but on the other hand, they used the same style plug all the way through CTC-5. I looked in my RCA field service manual, but all it shows is drawing numbers. The CT-100 drawing number for the yoke is 79116. If someone has the RCA parts cross reference, maybe they could cross this drawing number and see what part numbers come up...
Charles
Old 09-06-2006, 08:33 AM
Pete Deksnis's Avatar
15GP22 demo @ ETF 2007
Quick reality check: Andy, a CT-100 yoke uses seven of the eight pins on the connector. Pin 6 is blank. There appears to be one wire short in the picture. The mounting bracket also seems to be different from a production run set. A CTC4 should use all eight pins. Maybe that leaves you with a CTC5 yoke?
Old 09-06-2006, 12:32 PM
kx250rider's Avatar
Agreed... If for no other reason than the CTC-5 was a MUCH bigger production run than all the previous color sets combined. Hence more parts lying around. Thanks for noticing the wires & pins used... It was late & I didn't think to look at that BUT I did notice that the wires are plastic, and the CT-100 has asbestos/cotton wires on the yoke if I recall.
Charles
Old 09-06-2006, 01:52 PM
Old 09-06-2006, 02:50 PM
Originally Posted by andy
Pin 6 is unused and there is a jumper between 3 and 7. Pins 1 and 2 measure 59 ohms and have thinner insulation, so they are probably the vertical. Pins 5, 4, and 8 are the horizontal with pin 4 as the center tap. It measures 6.8 ohms.
Charles and I seem to have gotten faked out with this one. I get the same resistance readings with a Fluke 77 using an early-production CT-100 yoke.
You may/probably have a genuine CT-100 replacement RCA-manufactured yoke. An other possibility is a yoke from one of the kit-of-parts RCA was selling to rival manufacturers for development purposes in late 1953 and into 1954.
Any indications of use?
Pete
Old 09-06-2006, 04:29 PM
Old 09-06-2006, 05:09 PM
Steve D.'s Avatar
Steve D. Steve D. is offline
I bought this new in box RCA deflection yoke at an estate sale. It's part number 102285 according to the box which may not be original. The numbers 1106249-11 and 2746434-5 are stamped on the yoke. It's obviously to a large neck color CRT.
The number 102285 you indicate on the box is the RCA part # for the 21AXP22A CTC-5 yoke.
-Steve D
Old 09-06-2006, 06:01 PM
Old 09-06-2006, 06:55 PM
Originally Posted by Steve D.
The number 102285 you indicate on the box is the RCA part # for the 21AXP22A CTC-5 yoke. Steve D
My CTC5 schematic is locked up in a sick hard drive. To bring this full circle, can someone check a schematic to see if the CTC5 and CTC2 use the same yoke pin-outs.
Old 09-07-2006, 12:41 AM
kx250rider's Avatar
The following pinout shows jumpers and caps at the male yoke plug or internal in the yoke; not the chassis socket.
CT-100:
Pins 1 & 2 = Vertical
Pins 3 & 7 = Jumpered
Pins 5 & 8 = Horiz with Pin 4 Horiz windings center tap. Also a 270 Puf cap across one side of Horiz (pins 4 & 5) inside the yoke.
_________________________
CTC-2B (21CT55):
Pins 1 & 2 = Vert, and pin 6 is also shorted to pin 1
Pins 5 & 8 = Horiz with pin 4 Horiz windings center tap. Also a 150 Puf cap across one side of Horiz (pins 4 & 5) inside the yoke.
CTC-4:
Same pinout & cap value as CTC-2B
CTC-5:
Same pinout as CTC-2B & CTC-4, only difference is cap across one side of Horiz in this one is 82 Puf.
SOURCE: CT-100 & 21CT55; RCA Field Service Guide, CTC-4 & 5; Sams.
Charles
Old 09-07-2006, 12:45 AM
David Roper's Avatar
console lover
Puf?
tvontheporch.com
Old 09-07-2006, 01:48 AM
kx250rider's Avatar
Originally Posted by David Roper
Puf?
Slang for Picofarads (or mmf)...
Charles
Old 09-07-2006, 02:42 AM
Tom_Ryan's Avatar
Tom_Ryan Tom_Ryan is offline
Puf is slang speech for 10E-12 Farads. However, should only be written as pF.
mmf is micro-micro Farads or 10E-6 X 10E-6 = 10E-12 Farads. Equivalent to pF.
...not to be confused with uF or micro Farads which is just 10E-6 Farads.
Of course, Puf is also a short form for Puffs...a breakfast cereal...Charles must of had 82 puffs in a bowl!
Then again, puf is what you do when take a drag of a cigarette. Didn't know you also smoked?
