Old 09-26-2006, 01:59 PM
ozmoid's Avatar
ozmoid ozmoid is offline
Resident Frog
Monkey Wards Floor-standing radio
Well, Spring Cleaning is a little late this year but I uncovered this big guy under stacks of old Tax records (that may very well date back to when this thing worked!). I haven't had a chance to even knock the dust off, and probably won't for a while. It will go back where I found it for the time being, just thought I'd share some photos and see if anyone had experience with this unit.
Nothing outside you can ever give you what you're looking for. I'm gone fishing... see you at the pond.
Old 09-26-2006, 02:08 PM
I see 10, 11 tubes, counting the eye tube...Could be a Wells-Gardner...Betcha it would be a good performer...I'd date it from late '30s to mid '40s...
Old 09-26-2006, 06:15 PM
Brian Brian is offline
Looks complete. With a little work and a good cleanup of the cabinet, the unit will probably still get the Lone Ranger.
Old 09-26-2006, 07:03 PM
blue_lateral's Avatar
Ooooh.... I like that!
Old 09-26-2006, 09:09 PM
ozmoid's Avatar
Resident Frog
The only obvious things missing are the knobs. Obviously someone meant to start a restoration, and then stopped before they did more than lose the knobs and rough up a few places in the finish.
I am VERY intrigued by that "two-stage" speaker mount might have to pull that out and have a lookie-loo before I slip it back into it's cubby. I have so many things already occupying space in the house right now awaiting attention, I just can't tackle this big guy for a while.
And oddly, this is the third piece of mono gear to find me in the last little bit. Must be the hat. Yeah, that's it, definitely the hat.
Old 09-26-2006, 09:51 PM
CarlV's Avatar
CarlV CarlV is offline
Hey Sandy, should we tell him we have an Antique Radio forum here?
Carl
Nice radio ozmoid, so much class in the old floorstanders.
Old 09-26-2006, 10:30 PM
ozmoid's Avatar
Resident Frog
Carl
Thanks, Carl, don't give Sandy any reason to give me grief! I mean, it is TECHNICALLY a tuner, right?
I guess I knew the radio forum was there, I'm just so used to hanging out in that "solid state" area at the "top O' the page"™ I grabbed the first forum that fit!
Maybe a considerate mod will come along and move it for me?
And yes, this is a really classy unit. That amp/tuner section is HUGE, too. I also noticed there is a mono input on the back of the amp frame, and a switch for "TV" or "RADIO". Hey, it's an "Entertainment center"! Or maybe the world's oldest "multimedia" amp...
Old 09-27-2006, 04:50 AM
fotno's Avatar
fotno fotno is offline
Canis Major
Moved to correct forum at the request of its slightly addled original poster!
Some days, it's just not worth chewing through the restraints...
Old 09-28-2006, 03:30 PM
Chad Hauris's Avatar
This set looks like it has a triode push pull output stage, typically 6AC5 power triodes were used. Since these are low gain compared to pentodes or tetrodes like 6F6 or 6V6, there are extra triode driver tubes such as 6J5's used ahead of each 6AC5. These are likely the 4 tubes at the right end, 2 drivers and 2 output triodes. Also there will be another triode phase splitter tube.
We are working on a 1941 Crosley right now which uses the triode outputs and I have a silvertone at home which uses them. I can't say the sound sounds any better than tetrodes/pentodes so am not sure why they chose the triodes but it is an interesting variation...maybe to boost up the "tube count".
Chad Hauris
Old 09-29-2006, 06:51 PM
glen65's Avatar
glen65 glen65 is offline
Member
What model number is it?
Old 09-29-2006, 11:04 PM
I've got a couple similiar Airline/Wells-Gardner consoles, plus a down and dirty Truetone/Wells-Gardner. These are solid performers. One of the Airlines I have (a movie-dial) has that same speaker setup. Wooden knobs were typically installed. Some generic ones should be good enough.
Old 09-30-2006, 08:08 AM
ozmoid's Avatar
Resident Frog
Here's the label- and yes Sandy, it is a Wells-Gardner.
Old 09-30-2006, 12:09 PM
David Roper's Avatar
console lover
All fat-pin tubes and a TV sound input, that's wild. The "standard" glass types were all still readily available in 1939-42 (and cheaper than octals), but it's very unusual to see them used exclusively in any set later than 1936 model year.
tvontheporch.com
Old 09-30-2006, 06:10 PM
Tom Bavis's Avatar
Audiophool
Schematic and alignment: http://www.nostalgiaair.org/PagesByM...5/M0023385.pdf
Old 09-30-2006, 10:23 PM
ozmoid's Avatar
Resident Frog
Awesome Tom, Thanks! You rule
