Old 10-01-2006, 08:11 AM
Pioneer727's Avatar
Pioneer727 Pioneer727 is offline
SEMPER FI
1964 Magnavox Astro-Sonic
Hi all first post in this forum. I was given a Mint 1964 Magnavox Astro-Sonic. I have a Cap Question I want to replace the power supply cap in the future don't know where I can find one its a tin can type with dual values here is what is written on the the can.
Type FP
1000 MFD 30 VDC
500 MFD 30 VSP
What does the SP stand for is it AC
Ron
Pioneer
SX-1050
SX-980
SX-727
Teac A-3300S
Pioneer PD-F1007 CDP
Pioneer PL-115D
JBL L46's
Dayton SUB-100 Powered Subwoofer
Sansui
G-7700
8080
x2 AU-7700
Teac 2300S
JVC QL-F4 TT
Toshiba 3850 DVD
SP-2700's
Old 10-01-2006, 04:34 PM
Chad Hauris's Avatar
I think the "SP" indicates "surge" voltage rating. I would just replace with a terminal strip and some radial lead modern electrolytics.
Chad Hauris
Old 10-02-2006, 03:33 PM
Pioneer727's Avatar
SEMPER FI
Would anybody know where I can get a Sams Photofax or service Manual for this Magnavox Astro-Sonic Model # 1RP615 It also has the Micro-Matic model W603-18-02 Record Changer in it.
Thanks for any Help
Ron
Pioneer
SX-1050
SX-980
SX-727
Teac A-3300S
Pioneer PL-115D
JBL L46's
Sansui
G-7700
8080
x2 AU-7700
Teac 2300S
JVC QL-F4 TT
Toshiba 3850 DVD
SP-2700's
Old 10-02-2006, 07:54 PM
Tom Bavis's Avatar
Audiophool
Neither number is in the Smas index - Magnavox is usually listed by chassis number, on the amp and /or tuner. Changers were usually V-M.
Old 10-02-2006, 08:15 PM
Pioneer727's Avatar
SEMPER FI
Thanks for the Tip I will look at the chassis.
Ron
Pioneer
SX-1050
SX-980
SX-727
Teac A-3300S
Pioneer PL-115D
JBL L46's
Sansui
G-7700
8080
x2 AU-7700
Teac 2300S
JVC QL-F4 TT
Toshiba 3850 DVD
SP-2700's
Old 10-02-2006, 09:10 PM
Pioneer727's Avatar
SEMPER FI
First I want to thank you for the tip I found the chassis number on a sticker
Build Date 3/65
Chassis # R20512 00
as for the Record changer it had a sticker on the botom that says
Model # W 603-18-02
Part # 523456-12
Any Help
Ron
Pioneer
SX-1050
SX-980
SX-727
Teac A-3300S
Pioneer PL-115D
JBL L46's
Sansui
G-7700
8080
x2 AU-7700
Teac 2300S
JVC QL-F4 TT
Toshiba 3850 DVD
SP-2700's
Old 10-02-2006, 09:47 PM
Tom Bavis's Avatar
Audiophool
R2050100 and R2051300 are in folder 809-6 - that's probably it. It may list the folder for the changer once you find it. Here's my posting on where to find Photofacts... http://www.audiokarma.org/forums//sh...ad.php?t=82521
Old 10-02-2006, 10:17 PM
Pioneer727's Avatar
SEMPER FI
Tom your the man if there is any thing I can do for you Just let me know.
Big Thanks
Ron
Pioneer
SX-1050
SX-980
SX-727
Teac A-3300S
Pioneer PL-115D
JBL L46's
Sansui
G-7700
8080
x2 AU-7700
Teac 2300S
JVC QL-F4 TT
Toshiba 3850 DVD
SP-2700's
Old 11-11-2006, 12:45 AM
dano dano is offline
I could be wrong, but I believe that the Micro-Matic is a Maganavox version of the "COLLARO CONQUEST" changer. There's info about it here: http://mypage.iu.edu/~lrobins/collaro.htm They're supposed to be one of the best changers as I understand it, they automaticly detect record size and reject at a constant speed regardless of turntable speed. BTW, I have a AstroSonic console of similar vintage that I'd make someone a great deal on... it's currently in my dining room and has to go!
Old 11-11-2006, 08:01 AM
Pioneer727's Avatar
SEMPER FI
I think you are right mine does tap the edge of the record.
Ron
Pioneer
SX-1050
SX-980
SX-727
Teac A-3300S
Pioneer PL-115D
JBL L46's
Sansui
G-7700
8080
x2 AU-7700
Teac 2300S
JVC QL-F4 TT
Toshiba 3850 DVD
SP-2700's
Old 11-11-2006, 09:24 AM
Celt's Avatar
Celt Celt is offline
Peanut Head
Originally Posted by Pioneer727
I think you are right mine does tap the edge of the record. -Ron
Yup. Always thought that was so cool. Many also muted the signal from the cartridge during the change cycle.
Old 11-11-2006, 09:58 AM
Randy Bassham's Avatar
You're absolutely correct, sometime in the early 60's or late 50's Magnavox bought Collaro. The early ones sensed record size by a small finger that was located just to the left of the balance arm. Then they came out with the changer that the tone arm tapped the edge of the record to sense the size of the record, the tone arm sits down on the record about 1/4 inch in from where it was stopped, so if you came up with an 8 1/2 inch record it could play it just fine.
Around 1970 they cheapened up the changer and eliminated the second drive wheel that ran the changer mechanism. This changer still senses the size by tapping the record but the cycling cam has three grooves for 7, 10, and 12 inch records and arm sets down according to which groove is lined up by the record tap. On these changers the changer mechanism is ran off a gear around the center turntable bearing.
IMHO the early ones that sense record size by tapping the edge of the record and have a separate idler/drive wheel running directly off the motor are just about the best record changer used of the period. Very early Magnavox's before Collaro used Webster-Chicago and a few portables can be found with VM changers. There is a rare portable that uses the RCA 45 RPM changer.
I wish I had a dollar for every one of these changers I've worked on, about the only problems we had was due to hardened grease and dirt causing bearings and pivot points to lockup, and idler wheels.
I bought all the Magnavox service manuals from my former employer when he retired and closed up shop so I'm pretty well stocked up on service manuals if anyone needs a copy of one.
KAØSCR
Old 11-11-2006, 01:31 PM
Pioneer727's Avatar
SEMPER FI
I could sure use one for my 1965 Astrosonic the model and chassie number I gave earler in the thread post #6
Thanks
Ron
Pioneer
SX-1050
SX-980
SX-727
Teac A-3300S
Pioneer PL-115D
JBL L46's
Sansui
G-7700
8080
x2 AU-7700
Teac 2300S
JVC QL-F4 TT
Toshiba 3850 DVD
SP-2700's
Old 11-11-2006, 08:02 PM
Thanks
Ron
Send me a PM with your address......
KAØSCR
Old 11-11-2006, 08:53 PM
holmesuser01's Avatar
Randy set me up with the Collaro literature that he has, and I cured the intermittent "NO REJECT" problems that my 1962 Maggie console had. It was all due to dried up lube. It works great.
Playing a load of 78's these days.
Bruce
