Old 08-08-2003, 10:25 PM
Steve K Steve K is offline
Latest Color Acqisitions
I recently got two new old sets to add to my already overcrowded house, an RCA CTC-5 and a CTC-7. I recapped both and got them working fairly well although the 7 still needs some work in the burst circuits.
This is the 1957 Strathmore:
Old 08-08-2003, 10:27 PM
Screen pix from the above set:
Old 08-08-2003, 10:28 PM
Here's the CTC-7, the Wentworth:
Old 08-08-2003, 10:29 PM
Screen pix (albeit not the best color yet) from the above:
Old 08-08-2003, 10:30 PM
Rob Rob is offline
Banned
Steve,
Congratulations on the score and the restoration (the '57 Strathmore). That is a very cool looking set, and the color picture is very good.
Rob
Old 08-08-2003, 11:51 PM
Beautiful Steve! You make it sound so easy to get them going
The 5 has a really nice warm picture, what CRT does it have?
Old 08-09-2003, 06:50 AM
wiseguy wiseguy is offline
steve k ctc-5 & 7
nice sets steve,i am glad i finally got to see a pic on a ctc-5..! is that the original 21axp22? also is the chassis the special or super?,i put my ctc-5 away for now,have to order some more parts..
terry
Old 08-09-2003, 12:04 PM
Eric and Terry- as far as I know it has the original 21AXP22. It is the CTC-5N, super chassis.
Later today I will try to post a better screen shot of the CTC-7. I found out why the burst amp was not working, I had the leads of two components touching one another under the chassis. It's a scary thought that I'm working around high voltage isn't it?
More to follow if I don't do something else stupid and electrocute myself!
Steve
Old 08-09-2003, 01:28 PM
steves ctc 5
steve so your chassis is the version that uses wideband X-Z process?,how well does the convergence hold up so far?
my ctc-7 has a fantastic color,tracks well,.
terry
Old 08-09-2003, 01:46 PM
Steve D.'s Avatar
Steve D. Steve D. is offline
Steve,
Not to be picky, your Strathmore has the Deluxe chassis.
Old 08-09-2003, 02:51 PM
Oops- yes it is the deluxe chassis with wide band X-Z demodulation.
Terry- the convergence is pretty good. It came in better after I replace a 22 and 27 ohm resistor in the convergence circuit. BTW- check your private messages, I sent you some info regarding the CTC-5.
Steve
Old 08-09-2003, 02:53 PM
Steve Hoffman's Avatar
Steve Hoffman Steve Hoffman is offline
Mac and Roundie TV lover
Steve, where do you find these things (as if you'd tell)...
http://www.stevehoffman.tv
