Old 10-24-2006, 01:59 PM
John Folsom's Avatar
Build your own degaussing coil
The 21AXP22 datasheet recommends making a degaussing coil out of 425 turns of #20 enamel wire wound 12 inches in diameter powered by 115VAC.
(this is about 1300 feet).
You can wrap the coil in insulating tape and install a momentary pushbutton on/off switch in series with the line cord for ease of use.
John Folsom
