Old 01-20-2007, 02:35 PM
Chimes's Avatar
Chimes Chimes is offline
VK Member
Teletone TV-170
Need channel change and fine tuning knobs for the above Teletone. It is the 7" AC/DC set. See: http://www.earlytelevision.org/flea_market.html for picture.
Also need schematic and alignment info.
Thanks
Old 01-20-2007, 05:38 PM
The Channel and FT knobs on the ETF set are either incorrect or it has some oddball Radio option, (Steve?)
every 7" TeleTone I've seen uses regular RCA "Peanut" knobs, except the channel changer which is a peanut knob with a 1/4" shaft and a dot for a pointer.
It should also have a brass escth..... escutch... err, brass number thingy.
Old 01-21-2007, 06:14 AM
wiseguy wiseguy is offline
I think i have the brass channel part,i had one of those sets and it does use rca type knobs on the tuner,i'll look after work and let ya know..
terry
Old 01-21-2007, 01:17 PM
Chimes's Avatar
VK Member
Thanks guys, mine does have the brass channel indicator.
Old 01-21-2007, 04:43 PM
did it come with a free mouse inside..?..
wiseguy
Old 01-23-2007, 11:29 AM
fujifrontier's Avatar
fujifrontier fujifrontier is offline
roundie not so n00b
escutcheon
Originally Posted by TVTeufel
Another idea.....instead of expensive anti-psychotic drugs, let's provide schizophrenics with dummy bluetooth headsets. They'll easily blend into the crowd, although I suspect their "conversations" would be far more rational than those of the typical Wal-Mart shopper.
Ron
